Results 1 to 7 of 7
    Aug 01 2014
    Ohio
    Need help with axle
    Hi. Trying to replace my CV boots on my passenger side front axle. Have the axle out of the car but cannot remove the "tripod" that apparently should come off. Any tips or tricks or suggestions?
    http://www.audizine.com/forum/showthread.php/351334-A4-B7-Inner-CV-Boot-Replacement
    Following that DIY. Thanks
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Literally just did mine yesterday. Hold the axle with the flange head on the bottom, and hammer the section where the bolt holes are. Give it some force, but dont go crazy on it.
    Keep striking and turning it, itll come. If a bearing pops off don't worry, they pop back into place
    - if you have the flange off and you literally mean the tripod section, then you'll need to remove the retainer clip thats on top. Youll see a clip with 2 small holes on either end. Once that's off, youll be able to lightly hammer off the tripod
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 01 2014
    Ohio
    Quote Originally Posted by Schweini View Post
    Thank you for the reply. Yeah I have the flange off, and the top retaining clip, but now I can't get the tripod off. Been using a hammer and screwdriver
    Oct 16 2008
    South Florida - Ft Lauderdale
    Yes
    Gently tap on the base, as close as possible to the shaft
    It will slide out
    Phil
    May 22 2010
    N.E. Connecticut
    Don't use a screwdriver... Use a plastic / nylon deadblow mallet and a block of hardwood. You don't want to gouge the parts you are trying to remove. They'll just be harder to reinstall and may cause problems later on from being damaged. You need to use some force but not brute force.
    Thus why you want to use the tools I described..
    If you must use a hammer, ball pin or curved or straight claw then absolutely use that block. Never strike a hammer head on a piece of steel you ar trying to remove. One or the other can easily shatter. Since the strike point is very small and concentrated it is too much force. Something will give but not in the intended result...
    Aug 01 2014
    Ohio
    Thank you guys very much for the replies! After 6 hours and several part store runs, finally complete. Nothing but trouble. Why do I love this car so much lol.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Glad it all worked out for you
    Ya, definitely not a job im looking forward to having to do again anytime soon
    2008 A4 S-line 2.0T
    JHM Stage 2
