Results 1 to 7 of 7
    Dec 02 2009
    M3
    Dubai
    RS4 -Reverse, 1 & 2 not engaging post rebuild.
    Hi folks.
    -I have a B5 RS4, 2001 model with 170,000 KM on the odometer.
    -Due to some internal bearing failure. The crown gear on the pinion shaft got its gear teeth ground. Which caused metal shavings to mix in the gearbox oil. This caused a grinding noise from the gearbox.
    -Atthis time all the gears were shifting absolutely fine.
    -I decided to rebuild the entire transmission with new pinion main shaft+ crown gear+ all new bearings+ new seals & took this oppurtunity to upgrade with JHM motorsports 1&2 Syncro rebuild kit + OEM linkage + OE Clutch fork pivot were also replaced.
    -Now post the rebuild. Its very difficult to engage in reverse, 1 & 2 gears. Upshift & downshift. I had to really struggle to get them to slot in.
    -The rest of the gears were ok. Once in gear the tranny was smooth.
    -Please help me trouble shoot. Invested a lot of money into this gearbox build.
    Cheers
    Sam
    Jun 08 2014
    Vancouver, Washington
    Sounds like your shifter isnt aligned correctly
    Dec 02 2009
    M3
    Dubai
    Any online guides on how to adjust the OE shifter?
    Jun 08 2014
    Dec 02 2009
    M3
    Dubai
    Many thanks..!
    May 16 2008
    South Texas
    It sounds like a bad 1-2 shift sleeve or a clutch not disengaging. Shifter linkage problems are generally experienced in all gears.
    Jun 08 2014
    Definitely listen to this guy not me ^
