Results 1 to 8 of 8
    Senior Member Three Rings Blockis's Avatar
    Jul 25 2012
    Boston, MA
    Window Switch Not Working
    My front-passenger window switch isn't working. I can control (up/down) the window from my master switch, and "window-lock" is not active. The weird thing is that the switch lights up, but doesn't control it. And the motor clearly works since the master can control it... Any ideas??
    Paul
    2002 A4 1.8T Quattro | 197k ☠️
    2007 A4 2.0T Quattro | 155k
    Apr 17 2016
    kc
    I m no "old guy" or "diagnosticator" but why not just pull the door card off and replace the switch? Seems rather obvious😷
    Feb 02 2016
    02 A4 1.8t quattro Sport 5 speed, 87 4Runner (rock crawler), 06 4runner, 99 Suzuki Bandit 1200S
    Richmond, VA
    Yep, my bet is the switch. I had a few of them acting up and bought all of them with a new headlight switch and mirror switch from Amazon for like $30 and they work great.
    Jul 25 2012
    Boston, MA
    I replaced the switches a year ago -- granted, I bought them from eBay from a China seller, could that really be the case? lol...
    Paul
    Jul 25 2012
    Boston, MA
    Now I can't control the master window. I didn't hear anything, so I replaced the window motor, but it still doesn't do anything. I am thinking between ordering a new master switch or getting a new door harness (8E1971029C) as the speakers cut in and out and maybe there's some broken wires. Can anyone recommend a seller for master switch?
    Paul
    Senior Member Two Rings alpinevr's Avatar
    Feb 28 2009
    Spokane, wa
    It could be a CCM issue also. Best bet would be to get someone with vagcom to check and see if your switches are communicating with the CCM.
    08 Avus TI RS4
    17 Glacier SQ5
    Sold-04 DG USP
    Jul 25 2012
    Boston, MA
    So I held down the driver's window switch, nothing happened, but it looks like the CCM is recognizing it???
    Here's my VCDS scan:
    http://pastebin.com/raw/pgD9cb4w
    Most notably the CCM section:
    Code:
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 T
       Component: Komfortgerát T5B    0617
       Coding: 11788
       Shop #: WSC 63351
       VCID: 428B69B34E44CE2E28-4B00
       Subsystem 1 - Part No: 8E1959801
       Component: Tőrsteuer.FS BRM 0205
       Subsystem 2 - Part No: 8E1959802E
       Component: Tőrsteuer.BF BRM 0002
       Subsystem 3 - Part No: 8E0959801E
       Component: Tőrsteuer.HL BRM 0606
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0002
    5 Faults Found:
    01705 - Selection Switch for Mirror-Adjust (E48)
                27-10 - Implausible Signal - Intermittent
    01331 - Door Control Module; Driver Side (J386)
                80-00 - Single-Wire Operation
    01560 - Passenger Door
                59-10 - Can't Unlock - Intermittent
    01802 - Door Warning Lamp; Pass Side (W36)
                57-10 - Electric Circuit Failure - Intermittent
    01561 - Rear left door
    Paul
    Jul 25 2012
    Boston, MA
    I replaced the door wire harness (8E1971029C) today and it fixed the problem!!! Examining the previous one, one of the wires was cut, and there was a heck of a lot of corrosion on the terminals.
    Paul
