Was cruising on the freeway last night when suddenly the engine died lost power steering and check engine light pops up, was able to coast off the freeway and into a parking lot. Had it towed to my cousins shop and we just read the check engine codes.
Really sounds to us/me that it jumped timing, which I just did the timing belt about a month or so ago and it's been driving perfectly fine with no symptoms or issues.
Right now the car idles, but roughly and I do hear some ticking that wasn't present before. Not similar to rod knock though..
What are the odds the valves didn't slap the Pistons and cause damage to either?
Is it possible to jump timing and it causing absolutely no damage?
If it didn't jump timing, what else could be the issue?
5 codes total
P0016 - cam/crankshaft pos. Correlation sensor a - bank 1
P0300 - random/multiple cylinder misfire detected
P0301 - cylinder 1 misfire detected
P304 - cylinder 4 misfire detected
