Results 1 to 7 of 7
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5, 1988 ASC Mclaren Mustang 5-speed
    LI, NY
    B6 S4 Brake issue
    Alright so i just got done installing the S4 rears and now my parking brake wont fully disengage. In the car i pulled the ebrake and once it gets like an inch or two from being depressed fully it loses tesion. Not sure what i did wrong but i could really use some help guys.
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front & Cupra lip, S4 rear bumper, 18" BBS CH, OBX exhaust, PSI concepts test pipe, Genesis 380cc injectors, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, B6 S4 BBK, etc...
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    are you sure the parking brake linkage on the caliper is installed the right way ?
    Jun 21 2015
    LI, NY
    yes its installed correctly. After taking another look at it it seems to only be the rear left caliper. On the right side (working side) when i squeeze the parking brake linkage it moves pretty freely but on the left side its completely siezed. I'm assuming it may be tightened down a little to much?
    01.5 B5 S4 6MT SOLD
    Aug 26 2005
    If the parking brake is hanging up, then the caliper needs to be disassembled to fix the reason the caliper is seized up.
    Vorsprung durch Technik
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by B6ayfour View Post
    You should be able to squeeze the two levers that are tensioned with the return spring with or without the spring. Was that mechanism working when before you put the calipers on the car? As diagnosticator pointed, there's a spring inside the caliper, which holds the two levers in position (or only one, since the other is in a fixed position on the caliper). Sounds like there's some dirt inside that mechanism preventing it from operating smoothly.
    Take a look here and here.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Jun 21 2015
    LI, NY
    Well, this sucks. I don't recall if it worked prior to me installing it, will update tomorrow when i get the caliper off.
    This is a video from inside in case someone is having a similar issue.
    01.5 B5 S4 6MT SOLD
    Jun 21 2015
    LI, NY
    So we were wrong, took the ebrake cable off the caliper linkage and the caliper spring moves freely and perfectly. My cable looks rusty and old and does not retract or move at all. Thinking back on it i always noticed that my emergency brake seemed weak. Looks like im doing the cable now...
    01.5 B5 S4 6MT SOLD
