Results 1 to 10 of 10
    Senior Member Two Rings a4ced's Avatar
    Mar 07 2016
    Lehigh Valley PA
    Coolant leak driving me nuts
    So I've been chasing this problem for a while now. I'm losing coolant out of my 06 A4 2.0T Quattro. There's no antifreeze in the oil so it doesn't seem to be a head gasket, the turbo should be blowing smoke if I'm burning it which it doesn't seem to be, I just had the Temp sensor and temp sensor o ring replaced and I still seem to be losing coolant. It only occurs when driving, there is never a puddle under the car so it's not pouring out. Once a week or so I need to refill the whole resovoir.... I thought it was a heater core but the floor was dry in the car and I'm not having any heating issues. The only places I find coolant in the car are underneath it spattered basically everywhere and the puddle on top in the picture. If anyone can shed some light on this for me, I'd be very grateful.
    Sent from my SM-G928P using Audizine mobile app
    Active Member Two Rings Anton's Avatar
    Sep 15 2012
    North Jersey
    Had water pump replaced recently? I had to replace mine after change the timing belt as it was leaking, could not diagnose for a while. Additionally the rear flange is a common failure.
    Oct 16 2008
    South Florida - Ft Lauderdale
    Rear coolant flange
    Phil
    Veteran Member Four Rings Hightekflytech's Avatar
    Sep 24 2013
    I.E. Cali
    Rear coolant flange
    Phil
    That's the typical leaking location of the rear coolant flange. Not fun to get to
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    +4, rear coolant flange.
    Mar 07 2016
    Lehigh Valley PA
    Can anyone point me to a DIY? I definitely need to get that fixed
    Oct 16 2008
    Quote Originally Posted by a4ced View Post
    Sure = SEARCH
    Phil
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Sure = SEARCH
    Phil
    On a silver platter
    http://www.audizine.com/forum/showth...ment-with-Pics
    Sent from my SM-N900V using Tapatalk
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Feb 15 2016
    B8 A4, B8.5 S4, MK4 Jetta, 02 F250, 01 TJ, C5 Allroad 4.2
    Delawhere?
    Try this.
    If you have access to a lift it's much easier. Take a look from under the car and you will be able to see if that's where its leaking from. If it is the flange, I would think you would see a puddle under the car as much coolant as you say you are leaking. It could be the heater core, if it is you would smell it inside and you would probably get steam on the inside windshield.
    Nov 12 2015
    Orange County
    If the leaking is on the turbo-side rear engine bay. Definitely Rear coolant flange assembly.
