Results 1 to 8 of 8
    Sep 04 2011
    Central NJ
    5F-Information Electr. -- Status: Malfunction 0010
    When I use VCDS autoscan on my MY16 S6 (~1000 miles) I always get 5F-Information Electr. -- Status: Malfunction 0010 but there is no fault code found. Even after I clear all DTCs or erase (non existing) fault codes in module 5F, the malfunction 0010 is there when I run another autoscan. I use a Hex-Net with the latest updates and either VCDS beta 16.5.0 or VCDS mobile. Any suggestions how to get rid of this pesky malfunction message?
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Your car is brand new so you can just take it to dealership to check. Don't hesitate to mention about what you found from VAGCOM because that would help them narrow down for what they will have to look at. Just scanning your own car doesn't void the warranty.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Established Member Two Rings AOW162435's Avatar
    Jul 15 2013
    Ellicott City, MD
    hmuller,
    I just purchased a new Varta battery from the dealer and coded it correctly using VCDS. While I had the program active, I decided to do a full scan and found the same "5F Information Electronics Malfunction 0010" fault. As with your experience, the 'fault' remained even after erasing any DTCs.
    Did you ever get an answer on this?
    Andreas
    2014 Audi A4, Monsoon Gray / Black
    2002 Toyota 4Runner, Dorado Gold
    2001 Toyota 4Runner, Dorado Gold, 575,XXX 1-owner miles :)
    1998 Toyota 4Runner, Oxidized, 5-speed
    1995 Porsche 993, Polar Silver
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Those messages are related to MMI.
    Most commonly, on cars that the MMI firmware/maps were updated manually.
    I've done this myself and got that same code, but just followed the procedure to activate/reset those related codes and it goes away.
    An easy way to tell is if you go into your MMI version, and if the last part of your version starts with Kxxx instead of Pxxx that means it was updated. You might have to take it to the dealer to get it reactivated.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Same with my car, a MY16 S6. I just ignore it.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Sep 04 2011
    Central NJ
    I had that "malfunction" from the very beginning before any map updates. I had the dealership check my MMI and they didn't find anything. So at this point I also just ignore this "malfunction."
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Aug 27 2015
    New Zealand
    My car didn't have it until after first service, when they did quite a few firmware updates.
    Dec 19 2012
    Europe
    They need to reactivate your MMI, Maps, or Bose Module, or all of the above and it should go away.
