Results 1 to 9 of 9
    Veteran Member Three Rings ruiz's Avatar
    Apr 07 2009
    B5 bi-turbo avants
    MD
    What "aluminium" flywheel is this?
    I just pulled this flywheel from my old S4 and the previous owner told me it was an 034 unit but all the only marks on it are :AV-5 6842 along with an INA bearing. I tried to search the number but nothing came up. Any ideas?
    Senior Member Two Rings mr16valve's Avatar
    Nov 24 2013
    GreenvilleSC
    Physically looks like an 034, but the 034's are laser engraved with their info.
    Established Member Two Rings dirtydub01's Avatar
    May 28 2008
    Ohio
    Apr 07 2009
    B5 bi-turbo avants
    MD
    Nice, thanks for the help identifying it. Does it look like it needs to be resurfaced?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    fidanza/early spec. replace the friction disc, its ljke $50
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Active Member Four Rings
    Sep 14 2009
    s.e. mass
    aasco fidanza awe 034 spec all the same junk, ditch it before you have a tone ring failure.
    Billet steel TTV is the best option these days & the best price.
    IG: @PB5S4
    Jul 04 2012
    Woodbridge, VA
    I agree. I've heard it doesn't chatter like the fidanza. I'll be going that route when my fidanza shits it's pants.
    Apr 07 2009
    B5 bi-turbo avants
    MD
    I've heard great things about TTV and I was originally gonna go with a TTV flywheel but I thought I would see what was in my spare o1e first. The friction disk is about 9mm so it's not very worn at all.
    Dec 13 2010
    FL
    i have had 9lb spec flywheel in my 1.8t b5 and no chatter. i have also had aasco 9lb flywheel in my 1.8t b5, and again, no chatter
