Results 1 to 34 of 34
    Active Member Two Rings on3eighteen's Avatar
    Jan 15 2016
    NH
    A Financial, Not Emotional, Approach To APR's Stage 1 & Stage 2
    Based on the horsepower & torque gains from APR's website, it seems like a much better value to get Stage 1 vs. Stage 2 (https://www.goapr.com/products/ecu_u...30tfsi_c7.html). The gains from stock to Stage 1 are much more significant than from Stage 1 to Stage 2. Granted, the price for Stage 1 is $1,300 & to then go to Stage 2 is another $850 which is less, but the value you get per hp/ft-lbs increase seems so much better sticking w/ Stage 1. I know this is more of a financial take at this vs. emotional, and if we all had unlimited money we'd just go to Stage 2 & carry on with life. But I just went to Stage 1 & it's night and day. I called the local APR dealer & asked if I'd notice significant gains to now go to Stage 2 & he conceded that it's much less than what I've experienced so far.
    2012 Audi A6 3.0T, APR Stage 2 w/ pulley
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Yes I agree it is a less significant difference in the "butt dyno" department going from Stage 1 to 2. I would say stock to stage 1 is a 100% difference, stage 1 to 2 is maybe a 25% difference in perception of speed/torque. However, if you like the sound of cars and engines, then the SOUND that comes from adding DPs tremendously increases the amount of fun you have while driving the car.
    The $/hp cost is much higher for stage 2, especially if you consider the cost of downpipe install (these costs have varied from $400 to $800+ on this forum). I paid more than that but they also did a full exhaust install, not just DPs.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Mar 04 2015
    Houston, TX
    The higher you go in horsepower, the more expensive it gets for hp/$. Its always been this way, nothing new.
    Jan 15 2016
    NH
    You mention downpipes...I don't need to do that for Stage 2, correct? Just the pulley upgrade?
    Mar 04 2015
    Houston, TX
    Downpipes are for s6/s7 4.0tt. Pulleys are for the v6 supercharged
    Jan 15 2016
    NH
    I tend to drive mostly up to 4500rpm & not really to redline. Does the Stage 2 deliver power early on which would make it more worth it or is it only if I get to high revs?
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Quote Originally Posted by on3eighteen View Post
    My 2¢
    On my A7 which I just purchased pre owned, i immediately took it in and went stage 1. I scheduled stage 2 for a week later on that day as the installer was out of pulleys at the time. When I drove off stage 1, I was somewhat unimpressed until I figured out where that new power was, which is higher in the rpm range. Low end torque increase was nil in my opinion. Getting on the highway was fun for sure but winding the car out to get the experience I was after left me disappointed. Now, after leaving the lot after stage 2 install, a MUCH different experience. The pulley and software bring that stage 1 power down lower to where you notice it all the time. Now there is significant grunt down low and the car pulls very hard all the way thru whereas before with stage 1 there was a waiting period until north of 3k rpm before the effects were noticeable Yes i agree that looking at dyno numbers alone, especially only the peak numbers, paint the picture that stage 1 is plenty and the pulley doesn't make much sense...but take a close look at the torque curve and notice how at the lower end of the spectrum it starts to take off. Take it for what it's worth, but my opinion is that stage 1 is great and everything, but stage 2 yields a noticeably more potent motor. I drove stage 1 for just over a week before going to 2.. FWIW
    Sep 25 2012
    Quote Originally Posted by SlickMachine View Post
    My 2¢
    Completely agree. When I had my S4, stage 1 wasn't really that much of a change unless I was really revving the engine. Stage 2 on the other hand is noticeable pretty much throughout the entire rpm band. I think it's money very well spent.
    Jan 15 2016
    NH
    Well, that's EXACTLY the feedback I was looking for. And from somebody like me that has Stage 1, drove it for a bit, & then upgraded. I will let you know in about 1 week if I am a happy customer! Thank you for your quick feedback!
    Feb 21 2012
    Aurora, CO
    I have no doubt you will be grinning ear to ear when you land on that throttle. Best 2300$ you can spend on a car. Butt-dyno tested and approved.
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    Quote Originally Posted by tph4m86 View Post
    This... Diminishing returns sucks.
    For a V6 car, the pulley is huge. It makes a much bigger difference in the butt dyno than the numbers reflect.
    For a V8 car, the pipes are not as big of an improvement as Stage 1. They're good (I have them on my car and we're still constantly sold out of them), but diminishing return is definitely at play.
    Jun 02 2012
    CO
    I think if you lurk the B8 S4 forums you will see S2 is where it is at for the 3.0T. Seems to be a much larger difference maker.
    2021 Audi RS6 Nardo, CCB, Carbon Fiber package, Red Star Resonator Delete, IE Intake, IE Stage 1, Euro cup holder
    2020 Audi SQ7 Daytona Gray Pearl,
    Gone:
    2012 S4 Brilliant Black
    2016 S6, Daytona Gray Pearl
    2014 SQ5 Moonlight Blue
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Quote Originally Posted by Sean@APR View Post
    I think you start reaching the limits of the factory turbos on the C7 S6/7 by stage 2. Now if you were to go from stage 1 to stage 2+ which includes the RS7's turbos, I think you would find the jump more satisfying.
    Established Member Two Rings justcured's Avatar
    Oct 15 2015
    2013 S7 (Quartz Gray); 2000 Jaguar XKR Coupe (British Racing Green)
    FL Gulf coast; CA Bay area
    Quote Originally Posted by KnewJack View Post
    Says the brand new forum member to the guy from APR. Oh well, . . . .
    Apr 28 2016
    Quote Originally Posted by justcured View Post
    I was more so adding comment to the OP question using APR's statement. Nothing more...
    New to forum but certainly not new to forced induction nor building high HP cars doing most of my own work, thanks.
    Feb 01 2013
    C7 S6
    Opelika, AL
    Pretty much, yeah. if you can afford the turbos, do that!
    - - - Updated - - -
    I also started with 1 post. :)
    Apr 28 2016
    - - - Updated - - -
    Yes, we all gotta start somewhere!
    The RS7 turbos are a thing of beauty, the compressor wheels look like billet wheels. Are they? Also are they the IHI RHF55 or RHF6 or something else? Thanks. Impossible to find a compressor map for them.
    Mar 04 2015
    Houston, TX
    You increase boost in a supercharged car via pulleys and turbo cars via tunes, hence why the Better roi is on pulleys on V6s
    Veteran Member Three Rings Demandred's Avatar
    Jul 25 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    has anyone in the US gone down the MTM route ? don't see it mentioned on here much...if ever
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Apr 28 2016
    The APR tune increases boost on the B8 S4 by keeping the bypass valve closed longer in the upper RPM range, yes? Maybe not an overall increase in boost, but an increase I would think.
    Jan 15 2016
    NH
    The last question that I have is...is there any concern about reliability on the C7 engine in the A6 3.0T? I believe it's used in other cars like the much faster S4 so I'm thinking there's plenty of room for more power. I just don't want to be worried when I drive hard that I may do some $$$ damage!
    Feb 01 2013
    C7 S6
    Opelika, AL
    It's almost the same engine. There are some part number differences, but having tuned them for 6 years, we haven't seen any major problems.
    Feb 21 2012
    Aurora, CO
    3.0T is in S4, S5, A6, A7, A8, Q5.... There are a lot of these motors out there, which in turn drives down part prices. Check out the cost of a long block 2.5 vs the 3.0 block. Very durable motor as I'm sure APR would agree.
    Jan 15 2016
    NH
    Do you think the Stage 2 is any more risky b/c it's a hardware modification that Audi didn't really intend vs. the software modification in Stage 1 that's pretty much what the faster cars w/ the same engine like the S4 are built to handle?
    Jul 07 2015
    Midwest
    Stage 2 is absolutely more risky because it's higher output. More horsepower, more torque = more load and stress on drivetrain components. This is the same reason stage 1 is "risky". You're pushing the car beyond what it was engineered for.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by Demandred View Post
    MTM is virtually non-existent in the US these days. There were a numbers of vendors that sourced them years ago, but no longer. I think there is only one source for MTM in the U.S. in Florida. It is too bad. They make phenomenal products. Not sure why the U.S. presence is so bad. Does anyone know what happened to MTM in the U.S. ?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 02 2014
    Las Vegas, Nv
    You should just go stage 2, APR should have a summer sale going on sooner or later with the package deal on stage 2, that's what I did. The pulley was on back ordered when I got flashed to stage 1, so I drove it around for about a week waiting on the pulley to arrive. I thought, why do I even need to add the pulley when I just got all this power added from the flash? But it was already paid for so once it came in I put it on. Then I realized how much more grunt I just got off the line, the car really felt like it was digging into the ground and taking off. It's really surprising how much power this motor can make with a simple flash and pulley upgrade, throw on some exhaust with air intake and your golden.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    AKA: Yoshi123
    Jan 15 2016
    NH
    Just following up to see if you've had any reliability issues? Someone just posted on this thread to be very careful of harming the engine due to the significant increase in power that the internal components have not bee designed to handle.
    Feb 21 2012
    Aurora, CO
    Couple thousand miles on my stage 2, not a single hiccup.
    As for engine stress, I don't think you could argue that there isn't added stress on the motor with any software mod. I asked these questions to my installer and here is what i learned in a nut shell::
    I live in northeast Ohio, where Eaton corporation is headquartered. Eaton makes the blower for our motors. My installer has an acquaintance that worked at Eaton in an engineering role who shifted over to APR. He asked the same question about the pulley/spinning the blower faster/etc. He said they put that blower on a bench with that pulley and spun it at max load for a very long time with no failure (I believe he said for over 24 hours). I felt better about it after hearing that. Take it FWIW. Maybe an APR guy could get on here and verify that. I would like to know definitively what kind of testing was done on that blower.
    Jan 15 2016
    NH
    Day 1 into the Stage 2 & love it. I haven't even had time to really test but like everybody wrote the low end gains are fantastic. I cannot really imagine having a better car that combines luxury, quality, & performance for the cost. I'd have to spend another $50K to get something that'd be worth the price. BMW, Mercedes, Lexus...they've got nothing on these cars.
    Feb 21 2012
    Aurora, CO
    Nothing better in my opinion. I just picked up my 2012 A7 with low miles for literally exactly half of what it stickered for new, now I'm wasting mustangs and camaros in luxury with 4 doors. It's hard to believe that's only a 3.0 under the hood at times.
    Feb 21 2012
    Aurora, CO
    Don't forget to try your car in Dynamic mode if you haven't already...transmission stays right where there is a tremendous amount of torque available vs the everyday comfort mode. It's night and day different.
    Jan 15 2016
    NH
    I typically drive in Dynamic mode & notice it shifts around 3K. I read somewhere that if you quickly pin the throttle, even in comfort mode, it will automatically switch to Dynamic but I haven't gotten this to work. Any ideas? Also, is there a way to enable launch control w/ the APR tune?
    Apr 02 2014
    Las Vegas, Nv
    Ive never heard of or experienced the car switching driving modes from wot, you just switch it manually. Also LC is just brake and gas pedal at the same time, hold your tc button for 3 seconds untill its shut off, then hold the brake and rev to 3k, then release.
    AKA: Yoshi123
