hey can you kindly help or advise me? i am having problem with my key remote not locking/unlocking driver door and mirror switch not working(not opening and closing mirrors and cant control the mirrors) windows have always worked so i thought the broken wires i saw controlled the mirrors and remote lock. so i bought new wire harness to replace it and avoid resoldering wire and when doing so i noticed the socket from the frame to the door was corroded maybe it got wet through the spliced wires. new harness did not fix the issue. do you have any suggestion as windows are working just need the mirrors and the driver door to lock/ unlock with remote. it will open if i put key inside tho. feel free to reply or text me at 210-236-1224
- - - Updated - - -
These are two related faults
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: "Fg
Coding: 0035563
Shop #: WSC 08353 444 84413
VCID: 291A342B8016A37609-807C
1 Fault Found:
00532 - Supply Voltage B+
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 305068 km
Time Indication: 0
Date: 2016.05.07
Time: 20:42:27
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0035563
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 43
Mileage: 305004 km
Time Indication: 0
Date: 2016.05.06
Time: 14:55:03
