Results 1 to 12 of 12
Thread: Loss of audio
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Unhappy Loss of audio
    Sup fellas,
    I was wondering if anyone with a B8.5 has experienced loss of sound in their cars, specifically those with B&O.
    I’ve had it happen a couple of times now, randomly where sound would cut-off all of a sudden, for no apparent reason. Usually it happens when listening to music through Bluetooth (Spotify).
    If I switch source at that point, like say, change to Sirius, SD card, FM, etc., the sound is non-existent there either (stations are listed on the MMI screen, but it’s as if the system is muted). The only thing that fixes this is turning the car off for a minute or so, and restarting it.
    I’m trying to figure out if the culprit is the Bluetooth on my phone, the Bluetooth interface in the car, the MMI, or the B&O system. The fact that once this problem surfaces, and other sources (SAT, SD, AM/FM) are affected as well, makes me think this is something to do with the MMI/B&O, and not the Bluetooth interfaces on either the phone nor the car….
    Any thoughts?
    The car is under warranty, but if there’s something I can do to avoid a trip to that #$%@#^%$ dealership, I would like know.
    TIA
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Jul 05 2015
    Lower Hudson Valley
    Have you reset the MMI?
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by evanb View Post
    I did a specific reset just for the radio. Didn't feel like losing other non-related settings.... The radio reset didn't do anything.
    Apr 05 2016
    Portland, OR
    I've had this happen once or twice when listening to music off an SD card.
    Usually resetting MMI fixes it.
    I always assumed it was something to do with the SD card as that is the only time it happens.
    Geoff
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    what's your MMI version, upgrade it to 0814 might fix it.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by wangshuo1989 View Post
    I assume I need to take it to the dealer? If so, is there a cost associated with doing this upgrade?
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    your car is 2014, should still be under warranty , dealer should fix it even if requires software up grade at no charge
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Sep 05 2012
    Once or twice. I think once was after a car wash. Also, a few times I had one of the speakers not working and it took a while to notice the sound wasn't right. I don't really use the Bluetooth audio fwiw.
    I had the MMI unit replaced because of the volume knob problem (where it goes down two notches before increasing by one, etc) and I haven't noticed the audio cutoff since, but it was very rare anyway.
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by jygesq View Post
    Ugh... I hate taking it to these incompetent, careless morons.
    Jan 09 2016
    Yes, there were some codings involved. As for cost, it's free with warranty, otherwise expecting couple hundreds bucks from stealership..
    2021 BMW 540i
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Could this be an amplifier issue? In one of my previous vehicles, I installed an aftermarket system and one of my amps had a fan that went bad, which would make the unit overheat. Once that happened, some - and sometimes all - of the channels would shut down as a safety for the amp so it wouldn't completely fry. If I turned my stereo off for a few minutes to let it cool, it would play music again.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I've had it happen 3 times on my 2011. There have been previous threads about this and it is not uncommon. In my case, it came back after I turned off the ignition and started the car back up. Only happens with the B&O radios. BTW, mine happened while listening to the radio.
