Results 1 to 2 of 2
    Established Member Two Rings dp1199's Avatar
    Aug 22 2012
    2012 Ducati 1199s
    Columbus, OH
    2016 C7.5 S6 Headlight Warning - VAGCOM Fix
    Whilst messing with module [55 - Headlight Range], I caused the system to fault out. High-beam assist became inoperative as well. I replaced the long coding to the original factory settings but was still getting a "Calibration missing - Basic setting" fault in VCDS. To fix this perform the following steps (from memory so excuse any mis-wording):
    1. Select [Basic Settings - 04] in modele [55 - Headlight Range]
    2. Select [Basic Setting] from the pull down menu
    3. Click GO and wait for acknowledgement that the function performed properly
    4. Select [Acknowledge Basic Setting] from the pull down menu
    5. Click GO and wait for acknowledgement that the function performed properly
    6. Exit Basic settings and clear any existing DTCs listed under [Faults]
    7. Close the controller and exit VCDS
    8. Verify proper operation by turn headlights off/on and activating High-Beam Assist.
    Hope this helps someone with the same or similar issues that I had.
    dp
    Current 2016 Sepang Blue S6 Prestige | Driver Assist | Sport Package | Black Optic | B&O | Night Vision Assist | Carbon Atlas | Black Interior/Headliner |
    Current - 2015 Q5 TDI Prestige | Daytona Grey Pearl | Black Optic | S-Line | Sport Interior |
    Current - 2012 Ducati 1199s Panigale |Red |
    Current - 2015 Ducati Scrambler | Red |
    Sold - 2014 Prism Silver Crystal RS5 | MMI Nav+ | Black Optic | Driver Assist | Sport Exhaust | 20" Titanium Rotors |
    Active Member Two Rings Unnaturally A4's Avatar
    Dec 17 2016
    Fallbrook, Ca.
    Very helpful.....when I go to ABS it doesn't allow me to select go....any suggestions
    Sent from my SM-G930V using Audizine mobile app
