Results 1 to 40 of 40
Thread: Nitrous time
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Nitrous time
    I will be experimenting around with some dry shot (dry for simplicity) nitrous here shortly and will be starting off with a 30 shot. Car has RPM rods so I'm not too worried about breaking anything. I wil slowly bump up to a 75 shot while keeping track of all my logs to make sure I'm staying healthy. I know nitrous is some kind of forbidden voodoo to you guys but I like to party. Nitrous brings the party. Will post results after. Also any feedback from peeps who HAVE ACTUALLY USED nitrous is welcome.
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    SS4 ran a 65 dry (iirc) shot with 84 lb injectors, upgraded intank 044/stock fuel lines/rails on an RS6 setup for awhile.
    sfored has run nitrous on some of his S4s in the past as well. Considering a well sorted stage 3 car can bend a set of rods, it doesn't make a ton of sense for most to do it. I wouldn't say it's taboo for this platform anymore, though.
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Aug 06 2008
    Canadia
    Interested in replies, from what i have read anything under a 50 dry shot is safe on almost anything, plus its so low you dont have to refill the bottle very often, may be an easy way to get a stage 2 car up to stage 3 power.
    the B5 S4 is like the mafia... there is only one way out!
    Aug 25 2012
    Elmore alabama
    That's interesting^. Until you get the kid that sprays 24/7 and wonders why his shit blew up. Nitrous isn't a bs thing when you understand how to use it me apply it.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Just be careful, these blocks can't take an insane amount of abuse. Watch that torque if you get into the 650+wtq range. Low oil pressure and loose side main bolts are the signs of cracked mains.
    http://www.audizine.com/forum/showth...=1#post9208830
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    subscribed
    Dec 10 2013
    Borden, Ontario, Canada
    Someone should win the lottery and re-engineer the block for thicker, 6 bolt mains. Maybe billet?
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    nobody asked so i will..
    why not a wet shot?
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    im all for nitrous, preferably a wet one.
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by Bordom View Post
    We should just have find someone who would engineer a billet 2.7 block with all the bells and whistles. If only that was reasonably attainable.
    2024 M3 Comp xDrive
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    A year or so ago we had offered to design/manufacture a limited run of nitrous plates similar to the ones we make for the B6-B7 S4, but nobody wanted to pony up and buy them.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Quote Originally Posted by Jake@JHM View Post
    Lets go JHM we are waiting. If you design them and manufacture them, we'll try them.
    Oct 27 2012
    Lamborfeetes
    Washington
    The reason being for a dry shot over a wet shot is simply tuning. Our computers are MAF based and it's honestly just easier to tune for than a wet shot. It's also cheaper and easier to set up. I tune my own car and while I get the job done I'm not some wizard at tuning. I know my capabilities and what I feel comfortable with. A wet shot mixes with the fuel and you tube based off of AFRs while the MAF will auto adjust fueling based on your nitrous shot.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by a4kamila6 View Post
    Specially after the last offer, we would not even begin to make them unless at least 10 sets were paid for.
    ..and even then I don't think that is a project we have time to take on at this point in time.
    Sep 30 2015
    One day.
    Dec 13 2010
    FL
    Quote Originally Posted by mikeb17 View Post
    actually a wet shot is easier to tune for or not tune. it adds fuel, youncan run a wet shot with no additional tuning, cant say the same for a dry shot
    Oct 27 2012
    Lamborfeetes
    Washington
    You will have to tune for either way and my personal preference since I'm doing it is to just run it through the maf :) I feel safer this way. The dry shot is also cheaper and easier to set up. I thought about just tapping into my water meth bungs and doing a wet shot before the throttle body by I'm going with the dry shot. I'll post results up for you guys when I have it done. Couple weeks out.
    Dec 13 2010
    FL
    essentially a retune will net the most gains, but it is not necessary on a wet shot.
    all nitrous cars i ever saw spray post maf. have you ever shot it pre~maf before?
    Aug 25 2012
    Elmore alabama
    I'm excited to see what happens. Nitrous on an s4 sounds sweet
    Nov 03 2011
    All Over!
    Like boost, nitrous can be addictive. Run too much, and the motor won't last very long.
    1986 Type 85 Audi 90 quattro
    Oct 27 2012
    Lamborfeetes
    Washington
    Ive never played with a dry shot which is why I'd like to try it! I'm currently working on rebuilding a 454 for my chevelle and it will be running a double 150 wet shot.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Quote Originally Posted by GrapeBandit View Post
    Alot of people run dry shots pre-maf. Easiest way to get the car to add fuel.
    Dec 13 2010
    FL
    Quote Originally Posted by DieselElectric View Post
    hmm. that's news to me. what if your ecu cant compensate and add enough fuel, or what if your fuel injectors arent big enough to flow the requested fuel? all the reason for a wet system since it adds its own fuel.
    wet kit just seems more fail-safe to me
    Jul 04 2012
    Woodbridge, VA
    Nawz will turn a 10 second quarter into 45 seconds. Haven't you seen the movies?
    Oct 27 2012
    Lamborfeetes
    Washington
    Well I've changed my mind and will be spending a few more dollars and going wet shot. Usually you only run enough dry shot so your car can keep up with the fueling. However after more research I was reading on these disasters about MAFs getting too cold and actually freezing over with too much dry shot. Our cars literally live off of the MAF and I don't feel like blowing up my engine. Dry would of been cool and different but ill spend another 200 and go wet. I plan on tapping in right into my bipipes before he throttle body.
    Aug 06 2008
    Canadia
    I wondered about the freezing thing
    Nov 02 2014
    Winchester, VA
    I completely agree, I just know a lot of f-body guys do it. It's been a while though, that was back when they were still relatively new.
    I've already scaled back my MAF to keep it from maxing out load. I don't think I would count on a dry kit with it.
    Oct 27 2012
    Lamborfeetes
    Washington
    New and exciting news! My father is going to be making me throttle body plate for injecting nitrous because he doesn't like my bipipe idea haha
    Aug 06 2008
    Canadia
    Will he make more if we order 10 and give him a million dollars?
    Aug 25 2012
    Elmore alabama
    Sweet man! Always listen to dad, he has more sense than we do.
    May 16 2008
    WA
    Quote Originally Posted by MacDaddy View Post
    What threading is needed for the nitrous, could you just use this already made and available TB spacer for meth kits?
    http://www.usrallyteam.com/index.php...oducts_id=1699
    Oct 27 2012
    Lamborfeetes
    Washington
    Let me go see what size thread is on the nozzles and I'll report back. That right there could be the way to go. Getslideways... You keep me on this forum haha.
    May 16 2008
    WA
    Does that mean I am making your life better or worse? lol
    Always happy to help if I can, looking forward to seeing your project develop!
    Oct 27 2012
    Lamborfeetes
    Washington
    Thread size is 1/16. I see it doesn't specify the threads on that throttle body though.
    - - - Updated - - -
    And you make my life better lol you're hilarious and funny
    - - - Updated - - -
    Hilarious and helpful*
    Oct 27 2012
    Lamborfeetes
    Washington
    I also have a 1/8 nozzle as well.
    May 16 2008
    WA
    most of what I am finding for meth nozzle threading seems to be 1/8" npt, I would double check by emailing that spacer plate maker to be certain, but I would guess it will be for 1/8' npt. However I wouldn't be surprised if these are made to order, so they could likely put whatever threads you needed in it.
    Also, thanks for the kind words, you obviously have great taste in the company you keep lol
    Sep 09 2013
    i love nos threads
    00 allroad pj ko4
    Oct 27 2012
    Lamborfeetes
    Washington
    I was never interested in doing it until my father gave me his old nitrous kit from his old drag Nova. He ran a 6.08 eighth mile and a 9 something in the quarter mile. I believe he ran two 150 shots. I was given free stuff so I might as well use it. I'm just waiting on my heater, purge kit, and progressive controller before I go ham.
    Aug 04 2013
    Pennsylvania
    Would you need to trim the TBB to make that spacer work? I was just wondering how everything else would fit together with that since it's already pretty tight at the front
    I'm like a tree. I'm all root
    Oct 27 2012
    Lamborfeetes
    Washington
    Quote Originally Posted by APR-S4 View Post
    I'm kinda worried that it will cause the map sensor to smash into the hood which already happens enough with my 034 boot :/
