Results 1 to 20 of 20
    Apr 08 2016
    Macon, GA
    Might need a clutch?
    So after getting issues with my transmission jack fixed this week, I finally was able to pull my trans out and get started on putting a new clutch in my 1.8t. I knew before I bought this car that it needed a clutch but I didn't expect it to barley be hanging on like this
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Wow, I'm no expert, but that's quite wafer thing, isn't it? How did this clutch feel while driving? I'm just wondering what this kind of a mess feels like inside the car.
    Also, is that a Valeo SMF kit replacing it?
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Apr 08 2016
    Macon, GA
    It should be a testament to Luk's durability. It drove fine until about 2800 rpms and anything over 5 psi of boost and then it would stop slipping at around 4500 rpms. That only happened once before I decided to take it easy. Once I got the transmission out and started to remove the pressure plate, I was surprised at how much play was in the whole assembly. You could push the pressure plate in and it had about 3-4 cm of travel and could rotate it about 2 teeth either direction. Never once had a rattle though.
    And yes that's the Valeo SMF kit going in.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yup, that one is toast.
    Check out rock auto for a new flywheel. LUK ones are less than $200.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 08 2016
    Macon, GA
    That's actually where I got the Valeo clutch kit with SMF conversion. $328 shipped to my door with a coupon. Sad news is I'm a district manager for an auto parts company and RockAuto still beat my discount on the clutch kit
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by SquawkVFR View Post
    And if you are a frequent customer like myself you get an additional 5% off
    2000 S4- Working?
    Senior Member Three Rings Cousinphil's Avatar
    Jan 29 2015
    1954 Ford Jubilee Tractor,1986 Ford Diesel Tractor, 2006 GMC One Ton Dump, 1986 Nissan Flatbed Truck
    East Blue Hill Maine
    Mine's not slipping but it sure does chatter. It's passable if I give it a little extra gas when I let out the clutch. I don't how much longer I'll be able to nurse it along. I had already decided on a Valeo clutch. What is SMF? Something about the flywheel?
    2004 A4 Avant 1.8T 6 Speed 120,000 miles Summer
    2005 A4 Avant 3.0 Tiptronic 80,000 miles Spring and Fall
    2005 A4 Avant 1.8T Tiptronic 105,000 miles Winter Tires
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Cousinphil View Post
    Single mass flywheel. The OEM is a dual mass flywheel.
    Jan 29 2015
    Rock Auto has the Valeo kit for $166.79. That's a great price. No need to wait any longer. I see a new clutch in my future. Should I replace anything else while I'm in there? Do people replace the thrust bearing on Audis?
    Apr 08 2016
    Macon, GA
    I went ahead and did the throw out bearing and pilot bearing. If you're in there you might as well. Sime guys will tell you to replace your slave cylinder when you do a clutch but I've only done that when the slave and throw out bearing are internal.
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Not sure what most guys on here do but I did this job a few months ago and I replaced all the soft parts in the bell housing I could while it was apart, i.e rear main, trans input seal, pilot bearing and of course broken trans mount.
    Dec 28 2006
    Western Maryland
    For that price I assume it is only a replacement clutch pressure plate and throwout bearing. That isn't going to work with your dual Mass flywheel. You will need the full Valeo kit that includes a single Mass flywheel. And i would recommend replacing the pivot block, spring and post at the same time.
    Jan 29 2015
    The Valeo kit from Rock Auto includes the pressure plate, disc, an aligning tool, and something which might be a throwout bearing.
    Convince me that I shouldn't stick with the original flywheel.
    Dec 28 2006
    Western Maryland
    No need for a new flywheel if yours is ok. I wasn't aware that Valeo made a kit that worked with the Dual Mass flywheel.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    If you want to stay dual mass, using Lux pressure plate kit and flywheel from Rock Auto is about $350. Given how long yours lasted it's hard to find fault with the factory type setup. With such a reasonably
    Priced dual mass there is no real cost savings when converting to single mass.
    I ran that setup for a year and it was very good on my stock 1.8.
    Apr 08 2016
    Macon, GA
    For those of you who choose to do it stubbornly on the ground like I did, my advice is to turn your trans jack towards the front of the car for install. I've fought with mine for a couple of afternoons after work before spinning the jack around. 1st shot was the charm.
    Dec 28 2006
    Western Maryland
    LOL!! I wish I had a trans jack.
    I've changed mine three times with a floor jack, a strap and a board :-(
    And a lot of unprintable words.....
    Senior Member Three Rings johnwiz's Avatar
    Sep 08 2012
    2021 RS5, 2004 Audi A4 USP
    Leesburg Va
    I wish I would have spent the extra money on a better transmission jack, went with a cheap one - and I almost would have been better with just a floor jack. Actually wound up using the trans jack, with a small floor jack under the rear of the transmission. Made life much easier.
    Said POS jack;
    2021 Ascari Launch Edition RS5, BC Forged RZ 21 (20 x 10 ET 22); 2004 Audi USP, B&B Sport Exhaust, VMR Rims, Stoptech BBK, Motoza Hybrid K04 Tune, ER Sport FMIC, Frankenturbo F21.
    Apr 08 2016
    Macon, GA
    I used the Northern Tools middle of the road trans jack and it worked just like our Blackhawk post jack did when I was in the shop. Only difference was it used a chain vs a strap. It was about $170
    Aug 27 2013
    Philly
    Quote Originally Posted by johnwiz View Post
    Said POS jack;
    I had no problems with this jack when I did my 3.0 clutch
    Sent from my Nexus 6 using Tapatalk
