Results 1 to 7 of 7
    Jan 14 2016
    2012 S4 suspension issue -
    Installed H&R sport springs which are too low for me. Looking for either spring spacers (if they could give me a half inch extra height) or read on a forum of another B8 S4 owner installing RS5 suspension. Looking for additional opinions and sources where I could get the RS5 suspension used.
    Thanks
    May 17 2012
    Houston, TX
    Why not swap out for the H&R OE springs and sell your sport springs? OR is a mild drop but noticeable. Certainly never heard anyone say it's too low, even for those who never lower their cars.
    Oct 31 2013
    Morris County, NJ
    Go with oe. I didn't want to lower but needed to since it looked bad with the lower offset wheels and I love the ride and look.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Quote Originally Posted by AKPS4 View Post
    Why not swap out for the H&R OE springs and sell your sport springs? OE is a mild drop but noticeable. Certainly never heard anyone say it's too low, even for those who never lower their cars.
    This.
    OE springs are dirt cheap too. You can sell your Sport springs easily as well. The expense will be labor in swapping them.
    BTW - you should really consider upgrading the shocks while you're at it. ESPECIALLY with sport springs.
    Oct 31 2013
    Morris County, NJ
    Quote Originally Posted by MrFunk View Post
    This.
    For sure upgrade the shocks too.
    OP-I am in NJ pretty close to you so if you want to meet up and take a ride/look at my setup we could set something up.
    Jan 14 2016
    H&R sport springs are supposed to have a 1.5" drop, while H&R OE's have a 1.2". Not positive .3" is worth the labor cost. Also, I was not blown away by the H&R sport springs. Nobody commented on the possibility of installing RS5 suspension. Did you see this blog:
    https://dreamingin302ci.blogspot.com...=1463177446895
    Contemplating buying them from an RS5 owner swapping out his suspension. Of course, there are risks.
    If I were to go H&R OE springs as suggested, what shocks would you recommend that would constitute a real upgrade from the stock S4 shocks?
    Thank you.
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    OE's are closer to 1" not 1.2", especially on the 3.0T, apposed to say a V8 S5 or RS5 with the heavier motor. Eibach also has a good mild spring that pairs very nicely with a bilstein b8 sport shock, they actually have a full kit.
    Nobody really talks about the eibach spring because H&R is a more common name in the German field. But i know people who have ran both the H&R OE and the Eibach on stock shocks and actually prefer the Eibach for ride quality.
