Results 1 to 4 of 4
    Established Member Two Rings m47thew's Avatar
    Feb 03 2016
    2001 Sierra 1500 HD
    Quattroland, Canada
    brake flush w/ESP, VAG-com?
    Well I was planning on flushing my brake system this weekend when I replace my pads and rotors, but I'm seeing in the Bently manual that I should be activating my ESP pump for 10 seconds through the use of the VAG com.
    Did research and Ross tech seems legit but is a little expensive, maybe an investment but I definitely won't have it in time for this weekend.
    So this brings in some questions.
    For flushing the brake fluid, is it completely necessary to circulate the ESP pump for 10 seconds? I'm thinking it should be fine considering most people NEVER flush, I just want fresh fluid for when I bed my new brakes and head to the track this summer.
    What other options do we have for VAG com other than Ross tech... I currently have a WiFi OBD2 that reads all my codes fine through my iPhone, just no programming. Are there any new apps. what about handheld options?
    BONUS - Anyone in Edmonton that would let me borrow their VAG com?
    2001.5 S4 - Milltek SuperDual Exhaust, GIAC Xplus tune, 034 adjustable upper control arms (front and rear), density line lower control arms, front sway bar end links, rear sway bar + reinforcements, KW V3 suspension...
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Don't run the master cylinder dry and you shouldn't need to flush the abs pump, that is my understanding at least
    Dec 10 2013
    Borden, Ontario, Canada
    Flush all the things!
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    interested in replies, I'm redoing my wifes brakes and was going to flush the whole system, i know you can turn on the pump with VAG but have never used it for this.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
