Results 1 to 11 of 11
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    what would cause this?
    I was on a nice open straight empty road so I gunned it....
    not for too long (couple of minutes)... hit about 250 before I let up, and coasted up to a set of light...
    Once stopped at the light I could no longer change gears!
    Turn off the car, and I could shift... start the car, and no shifting!
    After a bit of trouble shooting I noticed that my clutch was not up all the way, and I pulled it up with my leg...
    Started up the cars, and was able to shift again...
    What could cause the clutch to get stock?
    thanks
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    I'd blame the slave cylinder for that
    Senior Member Three Rings prfktgntlmn's Avatar
    Sep 24 2011
    2017%20gmc%20canyon%20sle%20
    Atlanta
    OEM pressure plate.
    2007 Audi RS4 Phantom Black/Black Premium
    Feb 24 2010
    And have never been happier
    This is a common issue with B7 RS. Time for a clutch job unfortunately. Simply pull the pedal up during "quick" shifts if it happens again. And if you decide to take the car to a shop, don't let them grind the gear in.
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Very common with all Audi (at least with B5 A4). Slave cylinder going out. It is cheap, fix it quick
    Oct 11 2007
    Suburbia
    It's the self adjusting pressure plate, it's very well known on the B7 RS4. On hard runs I have to pull the pedal up a bit with my toe. FWIW, I have a solid metal slave and line, so it's not the slave acting up, it's the pressure plate.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Established Member Two Rings Christanza's Avatar
    May 08 2009
    2008 RS4
    Calgary
    I've been noticing that I'm beginning to get a bit of the "sticky-clutch syndrome" after stints at WOT. It's not quite at the point where the pedal remains stuck to the floor, but definitely feeling a bit "sticky" on the way back up. I had thought this was the slave cylinder as well, but good to know that it's actually the pressure plate.
    Is this something that requires a new pressure plate to be installed? Or is it just a matter of giving the plate a "tune up", so to speak?
    Established Member Two Rings seblove's Avatar
    Feb 28 2013
    los angeles, ca
    Quote Originally Posted by Christanza View Post
    Means your pressure plate is on its way out. Mine was sticking for a bit and eventually kicked me out of gear on a hard shift so I decided to upgrade clutch/flywheel/pressure plate. My mech said the pressure plate was in a pretty bad shape when he removed it - ie would have failed in due time. Go JHM R series if you're gonna drop the tranny anyways!!
    2008 RS4 Satin Pearl wrap - JHM stg 1+ blower - full JHM exhaust, resonated & catless - JHM LWFW & 3R clutch - PSS9s + 034 control arms & sways - JHM short shift + linkage - Apikol Rear Diff Mount - Stern Motor Mounts - 034 Snub Mount - 034 Trans Mount - JHM IM spacers
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Quote Originally Posted by WinterRunner View Post
    Interesting!
    I did a fair bit of searching regarding the "sticky clutch" and came with this as the best verdict:
    I had this same issue with my car. Clutch pedal sticking down particulary when changing down from high revs/heeling & toeing etc.
    First happened at a trackday at Spa last year and then did it fairly regularly after that.
    I had the modified clutch pipe fitted at my dealer as a first port of call, but this didn't make any difference. They then suggested changing the slave cylinder and then master cylinder if that didn't work. I didn't go ahead with this as I wasn't convinced that was it.
    I then spoke to Ben at Revo, who straight away said that it was a guide sleeve on the input shaft. Audi have produced a modified part, so they know there is a problem, but there is no recall campaign or goodwill!
    Unfortunately, replacing this part necessitates the removal of the gearbox, so I had a new OEM Sachs clutch fitted at the same time. The flywheel was fine (only 30k miles), so didn't change that.
    Problem solved!
    Now that you mention the pressure plate I'm a bit in doubt. Did you get the chance to change the pressure plate or get the info from anybody with a sticky clutch that did this change and the issue was gone.
    Ps: Sticky clutch syndrome also here, but not as much after a couple proper clutch bleedings.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Mar 19 2013
    The Spec clutch is also definitely one to consider. I've tried 3 different aftermarket setups and this one has been the most stocklike feel and has lastest the longest of them all so far. I have about 30k miles on it. Also happens to be one of the cheaper options out there.
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    you blew the clutch most likely.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
