Originally Posted by
kstaack
Hello,
I lurk the forum very often, and I want to do a manual swap to my BWT 2.0t tip. I have probably read everything there is to know about this swap, and it really does not seem too difficult at all. further down the line i want to do a 2.7t swap, and I want to choose the right transmission to set me up for success in that too. I am not even sure if they can be bolted up to the two different engines, so that is why i am coming to you. Any help is greatly appreciated!
-Kyle
It is with a heavy heat that I have to say this.. With what you want to do you would be better off selling that car for a 6spd manual awd car or even a 6spd manual FWD car as you would need to replace everything and do some ecu coding.
for the tip to manual swap you would need firstly to make sure the crank is able to adapt to a manual tranny (flywheel has to be able to bolt up)
You would need a clutch pedal assembly
convert from a tip shifter to a 6spd shifter
New center shaft
New fuel tank if you don't have a saddle tank already
AWD Exhaust
Clutch/flywheel assembly
and the fun coding of the ecu.
Now if you were going from a 6spd FWD to 6spd AWD then that would be the easiest conversion.
vizi
