    Veteran Member Four Rings A4_2.8tuner's Avatar
    Sep 16 2004
    1997 Audi A4 12v VRT (project), 2000 S4 stgIII, 2019 Nardo RS3, 2009 R8 gated 6spd, 2006 Lotus Elise
    St. Helens, OR
    Pulsating Vibration after clutch replacement
    Last weekend my clutch was replaced, and ever since i'm getting a pulsating vibration between 35-40mph under load. upon deceleration the pulsation discontiues and it becomes a constant vibration. I know if cannot be the clutch, as it is there with the clutch disengaged and RPM's dropped. The only things removed for the clutch job were the transmission and driveshaft. it also reappears between 75-80mph.
    I am curious if anyone has any ideas on places to start looking first, or any ideas on what they think it may be?
    TIA
    Instagram: brianbement
    EUROTUNER Feature-November 2009 http://www.superstreetonline.com/fea...-1997-audi-a4/
    Current Fleet: 1997 A4-Eurotuner feature car & current VRT project, 2000 S4 stage 3, 2017 Vegas Yellow S3, 2006 Chrome Orange Lotus Elise
    Jul 04 2012
    Woodbridge, VA
    Sounds flywheel related :(
    Sep 16 2004
    St. Helens, OR
    Quote Originally Posted by vavJETTAw36 View Post
    i dont think it's flywheel related, because as i said, it is still present even with the RPM's dropped down to idle upon deceleration.
    Jul 04 2012
    Woodbridge, VA
    How does that rule out flywheel?
    Id check heat shields and exhaust.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    It's going to be axles or driveshaft/carrier bearing.
    2005 A4 Avant 1.8t QTM
