Results 1 to 13 of 13
    Buncha motorcycles
    Memphis, TN
    Installed jhm shifter now parking brake won't disengage
    Well, shifter feels great but my parking brake won't disengage and says error. Any way to manually release it?
    Feb 23 2015
    Middle GA
    Is the switch plugged in?
    Buncha motorcycles
    Memphis, TN
    Yes, switch has power and it works but the computer says parking brake malfunction.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    it probably has something to do with the new shifter you installed.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Buncha motorcycles
    Memphis, TN
    Manual shifter causing electronic brake issues? Doubtful at best.
    It's probably something to do with unplugging the switch while the brake was engaged. Needs reset but I don't have software.
    Anyway, so is there a manual release anywhere?
    Jun 26 2009
    Bremerton WA
    The parking brakes are servo driven with no manual release. You may want to try disconnecting the battery and open a door so the dome light may bleed off residual voltage. Reconnect and see if it re initializes. The only way I know to back off the parking brake disconnect the harness at each motor and apply 12 volts to the 2 wires inside. polarity on the two pins determines motor turning direction.
    Edit: be sure to just momentarily drive the motor and not leave it connected to the power source.
    VMR 710's, APR software, Eurocode HFC
    Buncha motorcycles
    Memphis, TN
    So use a spare battery and apply a +/- lead to the wires inside? Is there a DIY on this?
    Jun 26 2009
    Bremerton WA
    It is mentioned in a few of the brake pad change threads.
    Jun 26 2009
    Bremerton WA
    Also noticed you have APR software. You can do a code clear using that and it may reset as well.
    Buncha motorcycles
    Memphis, TN
    That was old car . I have a trip tomorrow's. Any one have a link to the DIY?
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    The EPB will auto disengage when you apply the throttle while in drive or reverse.....did you try that?
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    I know this isn't exactly a DIY but if you get Carista you can do the parking brake motor on/off through your phone.
    +1 for @Crucible35 my brake will disengage automatically when you give slight throttle. I do not have AHH (only have the single function switch)
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by Crucible35 View Post
    It's a manual, didn't work. Dealer reset it.
