okay so cleared ecu codes today....and then installed new temp sensors (both 2 and 4 pin) still no fans, still jumpy thermostat. I ran the 130 and 131 here is what they looked like.
130
73 - engine outlet temp.
72 - radiator outlet temp.
96.5 - thermometer duty cycle
131
75 - engine outlet (actual)
101 - engine outlet (spec.)
75 - radiator outlet (spec.)
96.5 - thermostat duty cycle
ran the car around for a while thought I would post the codes...new problem of EVAP just came up...super.
Tuesday,14,June,2016,17:27:44:52038
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
VCDS Version 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: WAULC68E45A033766 License Plate: JUNE 14
Mileage: 170220km-105769mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAULC68E45A033766 Mileage: 170220km-105769miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 BC HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016711
Shop #: WSC 88641 551 633322
VCID: 72EB82766E6467AE78-5141
2 Faults Found:
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - MIL ON
18068 - Coolant Fan Control 1
P1660 - 002 - Short to Ground
Readiness: 0010 1000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04275
Shop #: WSC 26147
VCID: 2643AE26C22C4B0E24-5107
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63351
VCID: 63C5F732F19EFE2603-5141
1 Fault Found:
00819 - High Pressure Sensor (G65)
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 00000
VCID: 3561796A0F8A30969D-4B01
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 A
Component: SDAR XM 0010
VCID: 275DA322C52652061F-50AF
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351 000 00000
VCID: 3F8D1B426DB6FAC647-5141
1 Fault Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
008 - Implausible Signal - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenks·ulenmodul 0611
Coding: 01041
Shop #: WSC 63351
VCID: 3E7366463ABCF3CE4C-4B01
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 26130
VCID: 36637E66128C3B8E94-515F
WAULC68E45A033766 AUZ6Z0D0230197
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortger·t T7B 1612
Coding: 11880
Shop #: WSC 128887
VCID: 72EB82763E6467AE78-4B01
Subsystem 1 - Part No: 8E1959801
Component: Tırsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802E
Component: Tırsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tırsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tırsteuer.HR BRM 0205
1 Fault Found:
01562 - Rear right door
59-00 - Can't Unlock
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00020
Shop #: WSC 63351
VCID: 0407D4AE14D0591E5A-4B1B
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0410
Coding: 01201
Shop #: WSC 91392
VCID: 2C575C0EDCC0715EF2-50AF
End-------------------------(Elapsed Time: 05:57)--------------------------
