Results 1 to 7 of 7
    Junior Member Two Rings snatchman's Avatar
    Mar 27 2011
    2003 Cadillac Escalade EXT
    Columbia SC
    2000 Audi A4 will not start
    I have a Audi A4 2000 that will not start. I have narrowed it down to the clutch, either a safety switch or an relay. I have jumpered the safety switch that is attached to the clutch pedal and I am still getting the message press clutch in to start. So is there an relay I can check? Plus I have read in another thread that the convenience module in the trunk can cause this problem. How do I locate this module in the trunk? I also ran a scan, please let me know if you see something in the codes.
    Thursday,12,May,2016,12:05:44:04768
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    www.Ross-Tech.com
    Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine Labels: 058-906-018-ATW.lbl
    Part No: 4B0 906 018 P
    Component: 1.8L R4/5VT G 0006
    Coding: 07001
    Shop #: WSC 06335
    VCID: 2E53E54DEA05E54EDC-5140
    5 Faults Found:
    16795 - Secondary Air Injection System
    P0411 - 35-00 - Incorrect Flow Detected
    16825 - EVAP Emission Control Sys
    P0441 - 35-10 - Incorrect Flow - Intermittent
    18014 - Rough Road/Engine Torque Signal from ABS
    P1606 - 35-00 - Electrical Malfunction
    16725 - Camshaft Position Sensor (G40)
    P0341 - 35-00 - Implausible Signal
    17925 - Power Supply Relay for ECU
    P1517 - 35-10 - Electrical Malfunction - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
    Part No: 8E0 614 111 B
    Component: ABS/EDS 5.3 FRONT D00
    Shop #: BB 24332
    VCID: 1D31328197A36ED675-5122
    No fault code found.
    Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
    Part No: 8D0 959 655 K
    Component: Airbag Front+Seite 1002
    Coding: 00104
    Shop #: WSC 06335
    VCID: 3E73D50D3A6515CE4C-517C
    9 Faults Found:
    65535 - Internal Control Module Memory Error
    00-10 - - - Intermittent
    01217 - Side Airbag Igniter; Driver Side (N199)
    32-10 - Resistance Too High - Intermittent
    00588 - Airbag Igniter; Driver Side (N95)
    33-10 - Resistance Too Low - Intermittent
    00589 - Airbag Igniter 1; Passenger Side (N131)
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
    01218 - Side Airbag Igniter; Passenger Side (N200)
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 980 C
    Component: B5-KOMBIINSTR. VDO D11
    Coding: 02244
    Shop #: WSC 00000
    VCID: 2B55EC59D9179066FB-5140
    1 Fault Found:
    00667 - Ambient Temperature Signal
    30-00 - Open or Short to Plus
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 N
    Component: CV-Pump D11
    Coding: 16140
    Shop #: WSC 06335
    VCID: 408FABF54091633E3E-4EB2
    6 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06335
    VCID: 60CF4B75E051033E1E-4B32
    2 Faults Found:
    01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
    35-00 - -
    01382 - Alarm triggered by Anti-Theft Sensor; Front Left
    35-00 - -
    Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D003
    Coding: 00011
    Shop #: WSC 06335
    VCID: 65C15A61FF736616ED-51B6
    End-------------------------(Elapsed Time: 04:09)--------------------------
    Carolina for life!
    Jan 03 2015
    Vancouver British Columbia
    So it won't crank or anything?
    Established Member Two Rings CarlWeasly's Avatar
    May 25 2015
    Rockford, IL
    Check the camshaft position sensor. It shoes up in your vcds as implausible signal. Not entirely sure what that means yet but i know when i accidentally
    dislodged my cam position sensor's plug it gave me a no start condition. I'd look there to make sure everything's a-ok
    2000 A4 1.8TQM - k0mpresd stage 2 tune - Some other stuff
    Build thread here
    Jan 03 2015
    Have you don't any tuning on the car? Wideband conversion? Anything? Did this all of a sudden just happen?
    Jan 03 2015
    17925/P1517/005399: Power Supply Relay for ECU (J271 or J363): Electrical Malfunction
    That P1517 will also cause a no start, typically the cam code will will just cause "b map" fueling I think it's called, the engine will crank but is hard to start, often taking 5-6 tries to fire. I just dealt with that one myself.
    2001A41.8TQM Cat delete, 3"exhaust Turbonetics T3/T4 .63 A/R@18PSI, ATP Exhaust manifold, precision Turbo 39mm wastegate, Forge Splitter, FMIC, 80mm TB, SEM Motorsports Intake, AEB ported/polished, 3 angle valve seats with Supertech inconel exhaust valves/SS Intake, upgraded valve springs/ TI retainers, ARP head stud/main bearing stud kit, Skat rods/stock pistons, solid motor mounts, race density trans/snub/diff carrier mounts, stage 4 clutch with SM12lb flywheel, tuning by Motoza Performance
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    I had an issue with a relay on my auto 1.8T, 2000 In the ECU box theres a relay, mine was relay 30, I replaced the coils harness everything i could think of, didnt start. Changed the relay and started instantly.
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    Established Member Two Rings 2001BTA4's Avatar
    Feb 24 2014
    North East
    I second the #30 relay. Just happened to me last week.
