Results 1 to 16 of 16
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    AC won't turn on
    Just started today. The button lights up when I press it, but quickly goes back off. The fans still blow, but no AC.
    Any ideas?
    This car is getting tired of me.
    - clutch started getting weak a month ago
    - have lost 4-5 psi of boost and can't figure out why
    - sent back the K04 I bought, preinstall, because it had issues
    - found out that I don't have a real stage 2 file, despite what I was told all along by GIAC. I have what is called stage 2 minus. Supposed to make the same power, but the misinformation is frustrating.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    May 31 2004
    Could be the AC pressure sensor (TSB 2020124/12). Mine went and I had the same issue. Fan would blow but no AC.
    2011 2.0T P+ Sport 6MT, Integrated Engineering Stage II, STaSIS Exhaust, Spulen HFC, Roc-Euro SS, TDI FMIC, aFe Pro Dry Air Filter, E-Codes, 034 Transmission Mount, 19" AluFelgen SF-71, RS Grille, SunTek Carbon CXP 45, Shadowline Trim
    Deactivated Two Rings
    Oct 29 2015
    Bay Area CA
    My best bet would be the A/C pressure sensor also, I just got my a/c fixed and it was a pressure switch related problem. Do you have Carista or something to check it out with? If so you could prob save a lot of money, the app + doggle = $40 around and the sensor is 70$ so it could be worth a try
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by Haci View Post
    I have carista and vag-com. Will check for faults. Thanks!
    Oct 26 2012
    St. Louis, MO
    Senior Member Two Rings jorte014's Avatar
    Apr 16 2013
    Mercedes-Benz ML 350
    Coral Springs, Florida
    Quote Originally Posted by blbroo View Post
    Any ideas?
    Sorry to hear that, I had similar issues with AC and low boost.
    1. Recently fixed AC, turns out compressor just went bad
    2. Was driving with P0299 code (underboost) for a few weeks however the car was feeling sluggish long before then. I finally got tired of it and had it checked out - the wastegate actuator was so loose the wastegate was permanently open a little hence the explanation for the loss of boost. There is a clip you can buy that will clamp down on the wastegate actuator to reduce vibrations if it hasn't filed away to much of the metal around it. Mine was beyond redemption so I needed a new turbo. Might be what's happening with yours.
    3. Clutch recently started slipping in the higher gears after the new turbo since it restored ALOT of lost power and torque. Can't go past 50% throttle on any gear higher than 3rd.
    2014 S4 6MT - Milano Red | Premium Plus | Black Optic | Bang&Olufsen
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Any ideas?
    Seriously, or is "stage 2 minus" a joke? Did they also give you a really good deal on a Rolex?
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by The Fat Kid View Post
    Nope, stage 2 minus, which in my understanding of math is less than 1+1.
    I have a GIAC Stage 1.something tune, aka xplus, aka 2 minus.
    Mar 10 2015
    New England
    You should call it "Stage √3".
    Established Member Two Rings Iridium.'s Avatar
    Nov 07 2012
    Okanagan Valley
    Had a similar issue with a B6 A4 in the shop today. Econ light would stay lit every time you attempted to turn on the A/C (switches off when A/C is functioning correctly). Turns out there was a leak in the compressor housing. From my understanding, the pressure sensor will trip if it has failed or the system is too low (ie. not refilled correctly or leaking refrigerant).
    You can have your trusted indy shop drain what's left in your A/C system, then charge it with nitrogen and check the lines, compressor and condenser for leaks.
    Oct 26 2012
    St. Louis, MO
    Found the leak last night. Have a hole in the condenser behind the license plate holder.
    Ordered a replacement condenser from rockauto and will move my FMIC forward while I have the bumper off.
    Deactivated Three Rings
    Apr 28 2012
    ny
    What is this magic? Show me the way!
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Congrats on finding the source of the problem... such a good feeling to have!
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by Jerritt View Post
    Used a can of this
    http://m.autozone.com/a-c-charging-a...0_0/?location=
    Need a hose like this to deliver the stuff. Autozone has the same one.
    http://www.google.com/shopping/produ...UdkaAi3W8P8HAQ
    Put it into the lines with the car running and AC on. You may need to put some in, then turn off and on again to get the AC to kick on.
    Then use a uv light to find the leak.
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    And when you're done with the car, you can use it to find out where you leaked.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by ToddBrunswick View Post
    That's why I had a UV light in the first place.
