Results 1 to 10 of 10
    Feb 12 2008
    Michigan
    Central control module
    Is that the one under the dash? The one that controls Windows?
    Are those the same between b6/b7 or do they change like he one under the floor?
    Thanks
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    The one under the dash (Vehicle electronic control module) controls exterior lighting. The one under the floor (Central control module for comfort systems) controls the windows.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The central convenience control module is under the drivers side front carpet.
    2019 SQ5 Prestige
    Feb 12 2008
    Michigan
    Ok thanks, that would be b7 specific. Friend just picked up an 06 2.0 and the windows and moonroof are not working. He thought it was the the u set dash module, just needed to confirm. We have spare b6 parts but not 7.
    Aug 26 2005
    Quote Originally Posted by Fast4esT View Post
    Provided that wiring harness is the same between B6 and B7, you can substitute a B6 module in a B7. I don't know about the Comfort module under the carpet, but the CECM under the driver's dash cannot accept a B7 <> B6 module since the wiring harness is different.
    Vorsprung durch Technik
    Feb 12 2008
    Michigan
    the comfort control module is the one people swap out to use b7 keys, correct?
    Feb 27 2011
    Winnipeg
    yea for the 2002s, thats the one under the drivers carpet.
    Aug 26 2005
    For 2003> the comfort module does not need to be changed to use B7 key fobs.
    Dec 19 2011
    Colorado Springs
    I think somewhere you can check the part number of your CECM which is by the relay box under the drivers side dash near the dead pedal.
    There should be 2 different modules, the high line and the low line.
    btw....mine wasnt under the carpet, unless y'all are talking about something different and Im just an idiot..which is highly likely
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by B6A4Dave View Post
    you're talking about the central electronics module under the dash, afaik the NA spec cars all got the highline electronics. The one under the carpet is the central electronics module.
