Originally Posted by
Yoshi123
My apr dealer in town has a s4 b8 stage 3, he tampered with the duel pulley set up and after logging data he noticed that he was gaining power off the line but then the car would lose a significant amount of power off the top end. I hope this info is useful, IMO stick with a tune and sc pulley upgrade that's the best gain you'll see. If you want more add CAI, exhaust, headers and downpipes. This motor tops out around 500hp, if that's not enough go buy a sports car. 😄
Sent from my SAMSUNG-SM-N910A using Tapatalk
No offense man but that doesn't sound like good info. For one, unless you're talking about a TVS1740 set up from APR, you must not have meant stg3, right? If that were the case, that is a whole other animal. Two, it sounds like he ran into a tuning issue with the dual pulley alone. Just like stg1 with a pulley, there are likely zero gains unless the ECU is mapped not to bleed off the new, extra boost. This is why I bring up "stacking" files since I'm already APR otherwise EPL would be an obvious choice. Additionally, we might see heat soak as in the upper RPMs, the SC is out of its efficiency range. Again, in the case of your APR dealer, he was using an S4 which gets additional RPMs we don't get to take advantage of due to our ZF. This may work to our advantage in that respect.
As far as I know, the B8(.5) S4/S5 1/4 mile record is currently held by a guy with GIAC STG2 with a dual pulley set up, with Stacked software via Chipwerke Pro STG2. He is also running a mix of 93oct/E85. He did need to upgrade the cooler ultimately but did not do so immediately.
If I can buy a pulley and software, for less than it cost to go Stg1 and still see additional gains, that seems worth looking into before going out and buying a sports car as you suggest. I happen to like my car but a little added power is always welcome. And before any S6 guys state the obvious, again we are talking somewhere between $10K-20K on top of where I'm already at.
