Results 1 to 3 of 3
Hybrid View
    Jun 15 2010
    Chicago
    OBD2 port not working! Could it be a blown fuse?
    So today I tried to reset my service reminder light and also change the fuel map to 100 octane since I'm going in for a dyno next week. However, I just found out my OBD2 port doesn't work. A few months ago, I was tapping into the wires at the port for the P3 boost gauge install but ended up using a different source for the power. From then on, I haven't plugged anything into the port and before, it was working fine. Could it be a blown fuse? If so, where would be the location of the fuse? I bought the car used back then and it didn't come with the owner's manual. Thanks in advance!
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Passanger side , black fuse carrier fuse nr. 7 5amp.(fuses are marked/written on back of fuse box cover)
    Fuses on the passenger's side
    Some of the items listed are only fitted on certain models or are
    optional extras.
    Please note that the following list, while correct at the time of
    printing, is subject to alterations. If discrepancies should occur,
    please refer to the sticker on the inside of the fuse cover for the
    correct information for your vehicle.
    The seats with electrical adjustment are protected by circuit
    breakers. These reset automatically after a few seconds when the
    overload has been corrected.
    Fuse list
    Fuse list
    No. Electrical equipment amps
    Fuse carrier (black)
    1 Vacant
    2 Vacant
    3 Vacant
    4 Vacant
    5 Steering column switch module 5
    6 Electronic Stabilisation Program 5
    Fig. 285 Diagram of
    fuse box (left-hand
    drive vehicle)
    7 Diagnostic connector 5
    8 Gateway (diagnostic interface for data bus) 5
    9 Vacant
    10 Vacant
    11 Vacant
    12 Vacant
    Fuse carrier (brown)
    1 CD drive 5
    2 Switch module for Audi drive select 5
    3 MMI/Radio 10/20
    4 Light switch 5
    5 Control unit for instrument cluster 5
    6 Ignition lock 5
    7 Vacant
    8 Air conditioner blower 40
    9 Steering column lock 5
    10 Air conditioner 10
    11 Diagnostic connector 10
    12 Steering column switch module 5
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Mar 21 2015
    The fuse box is right next to the obd port. Why would you splice into that being so close to the fuse box.
