Results 1 to 7 of 7
    Jan 26 2015
    2017 XC90, a workbench
    CO
    New Ethanol content analyzer option
    First of all if you are interested then PM me. I do not make/sell these but I can put you in touch with the guy who does. He does great work and offers a bluetooth option, digital readout option like mine and/or single 0-5 V output. Price is good too. Cheaper than the alternatives.
    Here are some pics of how I decided to run everything. I removed like 9 bolts to loosen the glovebox and fish the cord through. (Wtf Audi - 6 bolts would have been ok). Hooked up the power via dual fusetap that I got at autozone. It powers on with ignition only. I mounted the LCD to the removable phone holder. Btw, the LCD would fit well in the ashtray and look badass for those inclined.
    I have run this for the past week and it has been flawless.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Nicely done. I may have missed it in the pics but where is the sensor?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Oct 13 2009
    MN
    Quote Originally Posted by cspcrx View Post
    Glovebox.
    May 11 2014
    United States
    Pm sent
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by CrownSeven View Post
    Glovebox.
    So your running fuel lines into your glove box?
    Jan 26 2015
    CO
    Hahaha. No. The sensor is just prior to the hpfp. Not bad to install. The analyzer is not pictured but is above the glovebox. It has an output to the LCD that is mounted to the glovebox. I am an amateur when it comes to this stuff and it really was not that hard, just mild customizing for where I wanted stuff to go.
    Jan 04 2013
    Phoenix, az
    Ok that makes sense now. If it would fit I could see sticking it in the ash tray, pointless item!
    So three parts to this system. Sensor, analyzer and display. What are the size specs on the analyzer and display? Also which sensor did you use?
