Results 1 to 2 of 2
    Registered User Two Rings
    Jan 19 2015
    Driver Door Jamb Socket p/n?
    I replaced the driver door harness that had spliced wires and foldable mirrors and lock/unlock had stopped working i thought because of the spliced wires, to find out that didn't fix the issue and noticed that the socket looked corroded. I am getting fault on vagcom
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H11 0040
    Revision: 00000000 Serial number: "Fg
    Coding: 0035563
    Shop #: WSC 08353 444 84413
    VCID: 291A342B8016A37609-807C 1
    Fault Found:
    00532 - Supply Voltage B+
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 305068 km
    Time Indication: 0 Date: 2016.05.07 Time: 20:42:27
    Please let me know if you are familiar with this fault and know what i have to do to fix or where can i find the part number for the socket, I would of thought it was the door control module but the door window works fine and it locks/unlock with the key inside the door, and also will lock from inside, its just the the foldable mirrors and the red light indicator for locked and unlocked on the door.
    Jan 19 2015
    also the key won't lock/unlock with remote, i have to manually open it.
