Results 1 to 4 of 4
    Apr 25 2015
    St.Louis
    911 EMERGENCY! Water in car!
    So a few weeks ago I put an aftermarket amp on the car. On the passenger side where the a/c line comes through the firewall there's a rubber grommet. I put the power wore through there, and until last week everything seemed fine. We got a weekend of hard rain and when I went to drive the car I could hear a lot of water moving in the car. Pull up the carpet and sure enough there's got to be over a gallon under the carpet but coming through. I also have the air bag light on now too.
    I got all that water up, and after inspecting the seal around the a/c line it wasn't sitting on there right. I couldn't get it seated so I remover it and sure enough inside there was water. Now I silicone packed that hole around there and after a rain a couple days ago no sign of water. Now today we got a ton of rain, and its back. I pop the good and the hole compartment with the battery, and around the cabin filter is standing water a couple inches high.
    Is there a drain that is supposed to get all the water out of that compartment under that shield? It's supposed to rain a bunch more tonight. I need help FAST!
    Oct 24 2015
    Perth, WA
    There should be a battery drain hole. Remove the battery and clear the drain.
    My respray thread
    Apr 25 2015
    St.Louis
    Thanks, I'll check that out!
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Check the sunroof ones while you're at it too!
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
