Results 1 to 20 of 20
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! Tow Hook License Plate Bracket Kits for your B8 S4!
    Why would you drill holes into your perfectly good front grille?
    Avoid drilling holes by using a tow hook mounted plate bracket from GMG! The No Holes License Plate Bracket does not require you to drill into your bodywork. Instead, it uses a custom-machined stud that screws into the tow hook receptacle.
    Simply add or remove your license plate without ever damaging your car.
    Kits include:
    • Tow Hook Bolt
    • Bracket
    • One-Piece Plate Holder
    • Hardware kit
    Don't Screw It Up - Screw It In.
    Fits:
    Audi B8/B8.5 A4/S4/A5/S5 (2008+)
    *It is recommended that the Tow Hook License Plate Mounting Kit be removed prior to the use of an Automatic Car Wash.
    Jason
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Does it not pivot 360?
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    What is that fog light or is that camera/sensor for active cruise?
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by MrFunk View Post
    No this does not pivot. The bracket is fixed but displays the plate flat.
    Quote Originally Posted by theswoleguy View Post
    Camera for active cruise.
    Jason
    Apr 04 2012
    MSP
    Shame no pivot. I think the plate looks bad flat. Needs a slight tilt to parallel the lines in the bumper and look more contoured.
    Sent from my SM-G925P using Tapatalk
    Sep 03 2009
    San Antonio, TX
    I'm sure it wouldn't be difficult to bend the thin aluminum bracket or find an alternative to meet your needs.
    Some people always tryin' to paddle upstream. LoL
    MY BUILD
    Oct 02 2006
    Wadsworth,OH
    It does contour to the bumper.. I meant that it desplays the plate flat like it's not curved or anything. But the actual mounting bracket allows for it to have a slight angle.
    I'm sure you could tweak the bracket for a more aggressive angle if you wanted.
    Jason
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    just ordered one today can't wait to get it
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Oct 20 2008
    Denver
    one of my biggest complaints with other companies' plate kits was that teeny little machine screw that holds the bracket to the tow hook mount. i've had trouble removing that thing well over 20 occasions throughout the history of all my cars. this bolt is a great idea!
    Oct 02 2006
    Wadsworth,OH
    Its pretty beefy that's for sure! A little anti-seize on the threads and it should come on and off super easy!
    Jason
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    is there enough clearance to remove this without disassembling the plate from the mount? looks like there is, but hard to tell.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Oct 02 2006
    Wadsworth,OH
    There should be. May require a stubby open ended wrench to loosen the stud that does into the tow hook location.
    Jason
    Veteran Member Three Rings UltraS4John's Avatar
    Sep 16 2006
    2013 Audi S4
    Northern VA
    "*It is recommended that the Tow Hook License Plate Mounting Kit be removed prior to the use of an Automatic Car Wash."
    I'd have to take this off every week. I assume the edge of the license plate would bend? If so, had the same issue w/ a similar plate holder on my B6 S4.
    2013 Audi S4 - Brilliant Black (Prestige) DSG + IE Stage 1 & STaSIS exhaust
    2013 VW GTI - Carbon Steel Gray Metallic DSG + APR Stage 1 & AWE exhaust
    2018 Audi Q3 - Daytona Gray Pearl DSG
    Oct 02 2006
    Wadsworth,OH
    I'm sure there could be a number of things that could happen by leaving it installed while going through an automatic car wash. I'm sure many would agree, but I try to avoid automatic car washes as much as possible. In the event I need to use one it's most definitely touchless - and even those are not that great for your vehicle due to the harsh solvents.
    Jason
    Sep 16 2006
    2013 Audi S4
    Northern VA
    Jason@ECS Tuning: you're absolutely correct about many things that could happen in an automatic brushless car wash but perhaps I should've asked if the plate holder is the same width as a standard US issued plate? If so, probably won't bend due to the bracket. I'd def consider one if the width is the same. The one I had on my B6 S4 wasn't as wide as the plate so it bent on the sides...
    Oct 02 2006
    Wadsworth,OH
    License plate is definitely longer on the sides than the bracket. You can tell by the how much further the license plate sticks out past where the mounting holes are at the edge of the bracket.
    Jason
    Sep 16 2006
    2013 Audi S4
    Northern VA
    That's not bad at all. The one I had wasn't as wide. Thanks for the pics Jason!
    Oct 02 2006
    Wadsworth,OH
    Sure thing!
    Jason
    Established Member Two Rings jackhossross's Avatar
    Mar 16 2016
    '13 3.0 Audi Q7
    Boulder, CO
    Are there any mounting options for the Q7
    '13 VW R || '13 Audi Q5
    www.instagram.com/jackhossross
    Looking for Q5 Lowering Static Lowering System - email: jack.ross(at)pga.com
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by jackhossross View Post
    Unfortunately not at this time.
    Jason
