Results 1 to 10 of 10
    Apr 29 2016
    Washington DC
    2016 s3 with Jb1 map6
    Hi all. My name is Wen and I recently purchased an s3. I came from a fully bolted and tuned Gen 2 Mazdaspeed 3. I'm glad to be part of the Audizine community!
    I recently installed the JB1 with default map 6 and I am encountering clutch slip at 3 - 6 gears.
    Video: https://goo.gl/photos/xbqGnJ74fE9qXVd78
    I removed the JB1 and brought it into the dealer to check the dsg fluid, which was verified as at the proper level (I don't fully trust they did this). Is there anything else I can check? I don't want to get a TCU tune since I'm only running a JB1.
    Apr 27 2010
    West Chester PA
    Trans probably IS slipping, only way around it is TCU tune unfortunately.
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
    Mar 13 2016
    San Jose, CA
    What boost are you making with the JB1 in those gears?
    Apr 29 2016
    Washington DC
    I'm using map 6 shipped setting which maxes at +5 psi
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    How many km's are on the S3?
    Mar 06 2016
    LI/NY
    datS3doe,
    the JB1 ships with the default map being number 1, boost is set at 4.75 psi.
    Map 0 is stock.
    Map 6 is a user adjustable boost profile which covers the rpm range from 1500rpm to 7000rpm in 500rpm increments.
    If you have any questions get in touch with [email protected] and he will help to answer any question you may have, he's a great guy !!!
    Good Luck.
    Nov 17 2014
    San Francisco, CA
    if doing launch control, are you experiencing the same thing on map 0?
    you shouldn't be experiencing clutch slip at all, take the car into your dealer... it'll be a headache, but they should address as that is not normal behavior.
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by datS3doe View Post
    I'm more curious about what your car is actually doing with the piggyback. The box's
    spec isn't always how things play out. If you're getting spikes, it could explain your torque issues.
    Apr 29 2016
    Washington DC
    2500 miles
    Apr 29 2016
    Washington DC
    I'm on map 6; did not change default numbers.
    It does not occur on launch control.
    I will log boost this weekend.
