Hi all,
greetings from Austria and sorry for my english, I haven't used it for a while...
I know, that is a well known issue, so have been searching the releated threads, but as i haven't found any wiring diagram, you are my last chance before I'm getting the whole interior apart to fix my trunk opener lid.
My trunk opener button, as the remote was working fine until I've installed a 12V socket in the trunk.
The new cable is running separate under the left side trims and between the backseat and the rear side panel. A separated fuse was installed in the fuse box, and it's just working fine.
As I've reinstalled the driver foot trim (!), I've heard the actuator opening the trunk one last time. As I was ready, wanted to open the trunk with the button, and it didn't work, only with the key, manually. I searched the forum, took off the trunk cover, deinstalled the actuator and tested it, working fine (!). Have the mechanical parts tested, moving fine and smooth. Then checked for electricity on the connectors, and the actuator doesn't get anything. (licence plate lights are do working). Also checked the harness between the body and the trunk and it's not broken (!).
Could somebody help me out with a detailed interior wire harness+interior connector location sheet and a wiring diagram till the fuse/relay box (!) for the trunk harness? It should be some continuity issue I guess, but I don't know where the harness is running and which connector and fuse/relay is to check for the missing 12V.
Thank you guys, best wishes
