Honestly I think we need to have Sticky about BBK and Braking options on this platform. For one the Dealer charges so much for a basic brake job that its absolutely absurd to consider the price for oem braking "performance" while I will say its sufficient for the car in day to day driving even the improved S brakes are leaving to be desired. Its a heavy car. Heat soak, and pad compounds are a real issue if you even wanna bang around the canyons or lakes one weekend, let alone decide to recreationally hit the track and melt your pads to the rotor..
Driving and goals are the biggest consideration here as Excelerate said. This however I think is always underrated. We all just say "I dont track my car, I just like to drive spirited occasionally" well if you do that in your 3500lb land missile you're a danger to those around you in the stock braking configuration. The RS brakes would be sufficient here, but even they for a day or two of track use with aggressive pads are pretty much useless.
The next consideration is budget. I consider this first lol. Because I dont care what my goals are if Im replacing something on my car, I'm improving it somehow. Nothing stock goes back on! But the brakes can run from a few hundred to 10k+ if you wanna go ceramic. There are so many HIGH END BBK at a low price point for this car its almost laughable to not have them.
Then comes tech... Not getting way into that bc thats what a sticky should be for. In short you wanna lighten your rotating mass, improve heat exchange, and retain longevity. The stock units actually the worst in all three categories. There are several two piece rotors on the market, start there. Then there are face considerations (Slotted, drilled) If you all season your car, I would avoid drilled. If you drive your car very hard, Id avoid drilled. Actually Id always avoid drilled lol. (tbh there is some value sorry guys). Adams, ECS, Stoptech, all have very affordable improvements. Start there. Then look into pads. Akebono, and the ST pads are pretty great. Hawk I've heard good things about, but never ran them, as well as pagid.
Then comes so much more...
Hope this helps. I should write the sticky.
