Results 1 to 18 of 18
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    Soo.. what is this issue?
    started the car and it revs slightly and goes back and almost stalls, checked to see if it was the ICM, it wasn't. when i hit the throttle it does this weird idle thing where it revs then goes to 100 rpm then back to 500, the car ran PERFECT yesterday and this weekend it was running fine, Replaced a oil sending unit BAM this happens, i didnt bump anything else i literally just reached down took the sending unit out with a wrench and put a new one back, Thats working, Now the car is doing this
    https://www.facebook.com/Trololololo...6805237361854/
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    Dec 10 2013
    Borden, Ontario, Canada
    Unplug the maf and see how it runs
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Sep 13 2014
    somewhere
    No change.
    Jun 30 2008
    Erie, Pennsylvania
    Reached down, eh?
    Wild guess: you disturbed/broke the delicate, almost glass-like PCV system somewhere - causing a good size vacuum leak. This unmetered air causes unstable idle and inadequate fueling due to unmetered air entry.
    Sep 13 2014
    somewhere
    Im pretty sure i didnt break anything because the car started fine and ran fine for about 30 seconds, then poof this
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    So you weakened something and the vibration / pressure from the engine running finished the job. That would explain why it ran and then died. Go look for broken hoses and electrical connectors.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Sep 13 2014
    somewhere
    Just checked theres no plastic pieces anywhere around where i was workinf nor under the car or sitting on the belly pan
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Throttle Body Alignment?
    2001 Corvette (C5) Z06
    Sep 13 2014
    somewhere
    Never touched it. :/
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by Radskull1 View Post
    Can you try performing one?
    Sep 13 2014
    somewhere
    Something else the obd 2 wouldnt let me check the codes
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    sounds like vac leak or throttle body is off
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Sep 13 2014
    somewhere
    checked the vac lines, Found only one small leak, Nothing serious no change
    Sep 13 2014
    somewhere
    i noticed that my AC isnt working now either, the fan runs and it shows like it is, But it was like this, i would hit the snowflake icon and it would stop blowing for a second chill the air all most instantly but that doesnt seem to be happening now, I let the car idle for 5 minutes, idle is normal, but the AC doesnt want to cool out now and it wont let me rev for more than 2 seconds, i checked all of the hoses used some smoke to check theres no air going in anywhere i can see besides the MAF, could there be some kind of electric problem, I unhooked the battery before i changed a oil sending unit, and it wouldnt let me start the car at first but i adjusted the harness on the battery terminal and it started this issue when i started the car, "Probably doesnt make much since" this is on the Cable driven 99 Preface lift a4, so im not super sure where to go from here, I checked the fuses including the ones under the dash, and nothing is blown..
    Sep 13 2014
    somewhere
    I don't actually think what im experiencing is a vacuum leak i can rev the car to 2k it waits 2 seconds then goes back to idle on its own i can rev to 4k and after the exact same amount of time it dies back to idle, the computer wont let me check the codes, It was working before maybe when i plugged the battery back up it shorted something out? doesn't seem likely but its the only strange thing that happened was the car didn't start when i plugged the battery up it just kinda died when i turned the key, i adjusted the terminal and it started right up, Idk what the issue is but i sprayed around even took the vacuum line off and put it on a smoke machine didnt find anything that way either
    Sep 13 2014
    somewhere
    https://www.facebook.com/Trololololo...9013833807661/
    Pushing the gas causes this issue. vacuum leak? also not letting up, Car just stops reving and tries to kill itself
    Sep 13 2014
    somewhere
    unplugged the MAF car died, "kinda was expecting that"plugged it back in, still having the throttle problem, Put car in gear, Idle goes way down and almost stalls the car, So is the throttle body or MAF the problem?
    Sep 13 2014
    somewhere
    https://www.facebook.com/Trololololo...9096060466105/
    Running through the gears, and the idle just slips when it goes in reverse and drive, but returns to normal in neutral and park
