Results 1 to 4 of 4
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! Tow Hook License Plate Bracket Kits for your B7 RS4!
    Why would you drill holes into your perfectly good front grille?
    Avoid drilling holes by using a tow hook mounted plate bracket from GMG! The No Holes License Plate Bracket does not require you to drill into your bodywork. Instead, it uses a custom-machined stud that screws into the tow hook receptacle.
    Simply add or remove your license plate without ever damaging your car.
    Kits include:
    • Tow Hook Bolt
    • Bracket
    • One-Piece Plate Holder
    • Hardware kit
    Don't Screw It Up - Screw It In.
    Fits:
    Audi B6/B7 A4/S4/RS4 2002-2008
    *It is recommended that the Tow Hook License Plate Mounting Kit be removed prior to the use of an Automatic Car Wash.
    Jason
    Oct 11 2007
    Suburbia
    This is the Go mini go bracket right?
    By the way, they go through automatic touchless washes no problem.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Oct 02 2006
    Wadsworth,OH
    I see no problem with touchless, but a standard car wash would surely damage the bracket and possibly other areas of your vehicle.
    Jason
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    That's perfect for car shows states that require front tags. Good Move ECS!
