Results 1 to 4 of 4
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! Tow Hook License Plate Bracket Kits for your B6/B7 S4!
    Why would you drill holes into your perfectly good front grille?
    Avoid drilling holes by using a tow hook mounted plate bracket from GMG! The No Holes License Plate Bracket does not require you to drill into your bodywork. Instead, it uses a custom-machined stud that screws into the tow hook receptacle.
    Simply add or remove your license plate without ever damaging your car.
    Kits include:
    • Tow Hook Bolt
    • Bracket
    • One-Piece Plate Holder
    • Hardware kit
    Don't Screw It Up - Screw It In.
    Fits:
    Audi B6/B7 A4/S4/RS4 2002-2008
    *It is recommended that the Tow Hook License Plate Mounting Kit be removed prior to the use of an Automatic Car Wash.
    Jason
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Group buy anyone? :)
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Lucca M View Post
    We unfortunately do not offer group buys.
    Jason
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    no needed PA state no have useless plate on front
