Results 1 to 12 of 12
Thread: Stalls
    Active Member Two Rings Jgreenway's Avatar
    Feb 21 2016
    TN, U.S.A
    Stalls
    So far i have replaced a head gasket, rebuilt the turbo, new plugs(E3), However the car is not running right and it stalls, I really don't even have time to get it to normal operating temp. . I have been through the car for vacuum leaks for about 3 days now and Have replaced a few lines. When i hit the gas ever so lightly it lags. Also i have found gas on the plugs so im guessing it is also running rich. Misfire codes for cyl 1,3 sometimes 2. Any help would be great. Thanks in advance.
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Quote Originally Posted by Jgreenway View Post
    What you working on exactly? 1.8t? 3.0L V6?
    You have Vagcom?
    Off the top of my head check cam belt timing.
    Pull those E3's out and put in the correct plugs.
    Of course check cam position sensor and crank position sensor. Among other things do a T-Body adaptation to start.
    And start to diagnose the misfire codes, is it a faulty injector, coil pack harness damage, faulty coil(s), low compression... u know?
    Feb 21 2016
    TN, U.S.A
    motor is a 1.8t and cam belt is almost perfect (i say almost because the arrow lines up on the intake side to the right side of the square hole just a little bit, I do not have a vagcom they are a little to pricey for me atm. I have however tried putting the old plug back in and nothing changed. crank sensor is new and T-body adaptation takes place each time i try something new, even if i just moved a coil pack from one hole to another, just incase. The coil pack harness is also new, just installed last week, I thought that was my issue but guess not.....
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Check your MAF.
    You can unplug it and see if the car still stalls or runs fine.
    Audi Club Bay Area
    Feb 21 2016
    TN, U.S.A
    No change from MAF when unplugged.
    Sent from my SCH-I545 using Audizine mobile app
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Do you have a boost gauge? Any leaks? Vagcom is priceless when it comes to diagnosing problems. Rather than throwing expensive parts at the car guessing, invest in a cable as soon as you can.
    2019 SQ5 Prestige
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Fuel pump dieing? Check the fuel pressure on the fuel rail, it should be 4 bar. Another thought would be leaking injector(s). You should find a cheap OBD-II adapter and get some info about how the car as running, as it would help a lot in figuring out what's going on.
    Sent from my DROID Turbo 2
    Feb 21 2016
    TN, U.S.A
    no gauge and i really want to get a vagcom AsAp. got a good site for a cable with a good price?
    Feb 21 2016
    TN, U.S.A
    i dont have a fuel tester but now its on the list of tools to buy, the obd scanner i have doesnt seem to give out much info. Only thing its telling me it that my cyl 1 it miss fireing and thats not all the time. I did change my plugs to the NGK ones, the motor was running earlier with a higher idle(more like normal). However it still died.
    Aug 26 2005
    You can search for more vacuum leaks by using a propane torch (not burning) with the gas on engine idling, trace all the vacuum system hoses slowly. A vacuum leak will pull in propane and the idle speed will increase/smooth out.
    Vorsprung durch Technik
    Feb 21 2016
    TN, U.S.A
    As of today the car will start and I can Rev it but only for about 30 secs to a min, then it bogs/stalls out, I did however hear a real small backfire sound
    Aug 26 2005
    Backfires indicate a lean air/fuel mixture due to several causes, the main cause is a vacuum leak somewhere.
    It is also possible the fuel pump is malfunctioning, failing to produce specified fuel pressure in the fuel rail. You should connect a fuel pressure test gauge to the test port on the back end of the fuel rail. Specified pressure is 4.0 Bar, ~58 psig.
