View Poll Results: worst B6/B7 S4 maintenance?
Voters
14. You may not vote on this poll
  • replacing the accessory belt
    0 0%
  • removing the rear brake calipers
    2 14.29%
  • bleeding the clutch
    5 35.71%
  • replacing fuses or relays under the ECU
    1 7.14%
  • other
    6 42.86%
Results 1 to 25 of 25
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    what's the worst maintenance to perform?
    what do you think is the worst (annoying, painful, frustratingly engineered) typical maintenance to perform on B6 & B7 S4s? "typical" being regular service and the replacement of fluids or consumable parts (brake pads, fuses).
    • replacing the accessory belt: service position, just for a belt.
    • removing the rear brake calipers: and you thought the engine was the only limited clearance?
    • bleeding the clutch: go-go Gadget arms.
    • replacing fuses or relays under the ECU: don't break your windshield!
    - emilio
    Jan 29 2010
    north ga
    Obviously......TIMING. everyone else just takes off the core support. For us you have to pull out the motor (sell you may not technically have to, but it's probably easier than trying to do it from behind with the motor in place)
    Apr 18 2012
    Central Texas
    i would definitely not consider anything timing related to be "typical maintenance" - though we might consider the all-plastic chain guides to be consumables, heh!
    - emilio
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Replacing the coolant flange, at least on the B7
    Veteran Member Three Rings zerokiller698's Avatar
    Nov 11 2011
    NKY
    Power steering line
    Current: 07' Q7, B6 S4
    Past: B5 1.8t, B6 S4, MK2 VR6
    Instagram: Zerokiller698
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Those German engineers who designed the B6/7. Are sitting somewhere right now laughing at our pain. I swear everytime my CEL comes on, I want to sell the car by a ticket to Germany and hunt down one of those engineers.
    This car is what I look like on the inside
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by ZERO FRAME GRAB View Post
    My CEL has been on since day one , lol
    Feb 18 2014
    Arizona
    somehow I didn't notice other or I would've voted for that for the timing chain guides. But out of the rest of the stuff, I chose rear brake calipers. I'ver never had to bleed the clutch with the engine/trans installed so I don't know how that goes, but I've done the rest and the bolts for the rear calipers are such a huge pain in the ass (only enough room for the open end of a combo wrench, so you gotta turn it like an 1/8 turn at a time), I'm gonna have to go with that one
    Oct 02 2005
    The Moon
    All of the items you mention are not that bad.
    Timing on the other hand is the clear winner for pain.
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by p3u View Post
    the actual engine pull is the tough part,
    I found the timing part very "fun" to do !
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Quote Originally Posted by jakeoboy67 View Post
    I agree. The actual timing part is actually pretty fun.
    Has anyone done brake hoses? Mine are cracked and rusted. Hopefully I don't fuck up the acually brake line that it connects to!!
    Sent from my SM-G900T using Audizine mobile app
    Veteran Member Three Rings emcaha's Avatar
    Mar 25 2013
    '17 VW GSW
    Burlington, VT
    How about replacing the battery? Feel like it's in the same boat as the recent IM tribute thread. Nothing like climbing on top of your engine to pull a 20+lb. brick from behind the firewall.
    Also heard A/C Compressor can be a real pain but haven't done myself.
    Feb 04 2016
    London
    Just done the battery on mine. Took about half an hour and a lot of head scratching. The trick is to use a long Allen key to get to the bolt on the hold down. You won't be able to get a socket down there due to clearance. Pulling the battery out from the side of the car wasn't too difficult.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by emcaha View Post
    Yeah, the A/C compressor is a giant PITA, and seems pretty guaranteed to fail.
    Mar 03 2015
    Easton PA
    LOL I swear man I also own a 01 Nissan Pathfinder & 02 Acura RL and the Audi CEL has been on and off in 6 months that those 2 cars combined in 2 years
    Apr 04 2015
    Salem, Oregon
    Filling up at the pump!
    Apr 18 2012
    Central Texas
    oooh, the battery is definitely a good candidate - i forgot about that one. sometimes i feel stupid for having to buy a tool for something so simple! and then once you get that bolt out you seriously need a friend's help or you'll just shoot a spinal disc across the garage.
    still, i wouldn't consider anything like timing components or burst hoses to be "typical maintenance", those are repairs or preventative maintenance. i'm more thinking of regular jobs that anyone who's worked on a few cars would think "swap the battery? no problem." except they are a problem, oh yes...
    - emilio
    Registered Member One Ring Tire.Spinning24's Avatar
    Nov 29 2013
    U.S
    Quote Originally Posted by Vertol View Post
    Haha! I feel yeah
    Oct 29 2015
    Richmond VA
    Quote Originally Posted by emilio View Post
    - emilio
    Didn't realize they were a pain; all the sudden I'm glad mine got a brand new one right before I bought it.
    I've had nightmares with the power steering lines
    2013 TT RS (Sold)
    2013 Allroad (Sold)
    2017 S3 (sold)
    2006 25 Quattro S4 #50 (dead)
    Apr 04 2015
    Salem, Oregon
    - emilio
    I laughed at the image of one of your discs shooting across the garage.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    I laughed and felt the pain at the same time.
    I'm going to nominate the alternator as well. Just replaced mine about a month ago, huge PITA. Took me somewhere between 8-10 hours start to finish.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Nov 11 2011
    NKY
    I've replaced the following with personal ratings:
    Battery - 5/10 because of the akward reach and weight
    Front Wheel bearings - 7/10 former NY winter driver car, bearing housings seized in the knuckle
    Fuel pump - 6/10 because I had a full tank of gas
    Power steering line - 9/10 would be a full 10, but a recruited help
    Rear calipers - 2/10 put a short reach allen key, then a closed end wrench on it and presto, easy
    Wiper transmission - 3/10 can't believe I had to do this twice in 2 years, gets easier the more you do it
    Pinch bolt removal - 8/10 We all know this one, with out the special tool for this, ugggg
    Radiator - 5/10 really can't say much besides service position
    Putting gas in the car - $/10
    Mar 25 2013
    '17 VW GSW
    Burlington, VT
    Great call on the wheel bearings. Existing was seized in mine as well and took an air hammer and about every word in my vocabulary to get it out. New ones don't come as an assembly so have to get the bearing and hub pressed together. (Easy for me as I can do it at work but def something most can't do themselves).
    If you have to do a rear then you'll also have to deal with those rear caliper bolts too. Win-win.
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    Having a rust free AZ/FL car makes several of the above complaints go away. I'll toss a vote in for the rear springs -- especially when compared to the B5. I'll also add the CTS, which is my next job.
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by TEB View Post
    Yeah the rear springs are a huge pain. I fought with them for a long time before I just decided to drop the subframe and save myself the hassle.
