Results 1 to 40 of 42
    Apr 29 2016
    Pennsylvania
    New to Audi lowering springs question
    Hi, just purchased S5 cab 2 weeks ago. First thing i did was put some 20X10.5 wheels with et27 and 275/30/20 tires on. Looks pretty good but i think she need to sit a bit lower. Im looking into H&R OE and Eibach springs for a subtle drop. But do i need to grab specific cab springs or would the H&R OE do? Any recommendations or pics of cab lowered on 20s would be appreciated.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    I can recommend the Eibachs over the H&R, a really nice handling and riding spring, also take a look at KW H.A.S, another nice riding spring.
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    If your car has ADS.. KW HAS is the only way to go.
    - iKe -
    2011 S5
    2011 A4 Avant
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    Quote Originally Posted by JamesRS5 View Post
    Interesting you say that. I know the H&R OE's are the most "popular". I have the V8 which helps get a better drop towards the front. But what makes you like the Eibach better?
    Only reason I went H&R OE is because I got them from a friend who had them sitting in his garage. He switched to coils to get lower. I just wanted to rid of wheel gap & retain OEM like comfort.
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Quote Originally Posted by Avantmaniac View Post
    I second this. Love mine.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Oct 14 2013
    Bay Area
    Are the KW HAS a good option for those with non adjustable suspension (ie USDM RS5)
    Established Member Two Rings ironman9's Avatar
    Jan 25 2016
    Brunei
    How do you tell if your car has ADS? is it the drive select button thing?
    Jan 25 2016
    Brunei
    is the H&R OE Spring only available in the US market? because I talked to the H&R over at Malaysia and they said that the OE spring is for the US market and H&R Sports spring is for the Asia market. I'm kinda confused now. My audi A5 has the drive select and I'm looking to lower my car with a nice springs which gives a nice ride. right now, my car is too "bouncy" when I drive fast. lol
    Feb 27 2014
    Dubai
    Quote Originally Posted by Vanimal View Post
    H&R are popular but quite a lot of guys report the ride is bouncy on the H&R, I've also read this on other car forums. H&R go about their lowering differently than Eibach, have a read of this thread I made last year:
    http://www.audizine.com/forum/showth...-Sport-Springs
    You make your choices and pay your monies but it depends what you're looking for, just purely lowering or lowering and keeping the ride and handling.
    May 20 2015
    PA
    I was just asking, I went H&R because I got them free from a friend who switched to coils to go lower. So I figured I'd try them as well as him helping me out them on so can't argue free labor.
    With the money saved I figured it would be smart & IMO the correct & longevity way. Is to to pair the H&R OE's with Bilstein B8 sport shocks & struts. I think with the B8 sports & struts both Eibach & H&R will give a great ride which is what I've read on here & the B8 S4 side. I didn't bother with coils because I'll never go that low & I'd have to get a upper tier coils because of PA snow & weather. Even the H&R's I think would probably rust out eventually.
    I was just looking to lower about 1" to rid of wheel gap, keep a OEM ride with a little bit better cornering.
    Feb 27 2014
    Dubai
    I'm not saying there's anything wrong with H&R, just given the choice I'd go with Eibach but for free, you can't go wrong. My initial response was to the thread starter who asked which springs to go for.
    Bilstein chose to pair their dampers with Eibach for a reason.
    Apr 29 2016
    Pennsylvania
    I will go with Eibach. Im new to all this so do i need springs, Bilstein shocks AND struts on the S5? Or just shocks and springs?
    Feb 27 2014
    Dubai
    If your current shocks are good with not too many miles on them then they should be fine with just the springs. If you want to upgrade the shocks you could go for Bilstein but then you're getting in to KW coilover territory money.
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    @Swag I've been there before. I installed a set of 20 x10" et27 wheels on my '11 cab and looked for the best way to achieve a subtle drop. I'll caution you that the cab weighs approx. 400lbs more than the coupes. I tried a set of the H&R Street Coilovers and the highest setting I was WAY too low. Rub city! The part number is the same for both cabs and coupes so choosing a cab for the application doesn't mean you are getting a product specifically designed for the cab. I'm not sure which spring H&R uses but I swear it wasn't designed for the extra weight of the cab.
    I switched out the H&R setup for the Bilstein PSS10 setup. The PSS10 offers greater flexibility in ride control and height adjustment. With this application the cab sat perfectly at the highest setting and eliminated the wheel gap but I wasn't able to go any higher as needed. The ride was good overall but have to admit, in colder temperatures I felt the "bounciness" and did rub from time to time.
    My opinion is the H&R OE and Sport springs will sit too low. My cab is now gone and replaced with an RS5 coupe, where I'm currently trying the KW H.A.S.. So far so good. This may be a happy medium for you in the cab as you mentioned a "bit of a drop". My vote is to give the H.A.S. a try as you'll get more flexibility in ride height adjust.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Jan 07 2011
    2013 C300 4Matic
    I had eibachs on my v8 s5 and it road a bit like oem, but a tad bit rougher
    my other buddy had oe springs and he said it rides like shit
    really depends how one defines " rides like shit" or "feels oem"
    this is mine on eibachs and 19's
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Feb 27 2014
    Dubai
    This is mine on Eibachs
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Here's mine on OE's with drive select. It's a tad stiffer than OEM, but they gave me the 1inch drop I was looking for with my wheel set up. I would have gone with Bilstein struts, but my car only had 25k when I installed the springs so I said I would ride out the OEM struts until they are done. I'm at 50k miles now and so far so good. I'll upgrade to the Bilstein struts when these are done.
    Another note on comfort...they could be a tad more comfortable, and if the road is super bumpy, I put it on "comfort" and it makes a huge difference. Overall I am happy with the drop and the ride for the price.
    Hope that helps!
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    May 21 2010
    Quote Originally Posted by DreDay View Post
    Hope that helps!
    THAT looks perfect to me.
    May 20 2015
    PA
    That drop looks awesome. That's the exact drop in after. I know ride quality is subjective, but perhaps I will look into the Eibach springs. I see so many people go H&R OE you'd think that's the best choice. Maybe those are the 3.0T guys?
    May 20 2015
    PA
    Hope that helps!
    Those drops look perfect as well! @ Dre yeah at 25k i wouldn't have upgraded the shocks & struts yet either, i have read people have gone 50k and still going on mild drop springs, guess it depends where you live.
    @ James, I did notice Bilstein makes a B8 shock & strut kit that comes with the Eibach springs not H&R, maybe they pair very well with them.
    Jan 07 2011
    2013 C300 4Matic
    ppl don't venture out of brands much. when they think german, they think h and r automatically. eibach is more of a jdm brand I feel, they were very popular in the infiniti world, so I gave em a try. they were priced almost 100 less than h and r's, so I gave it a shot, and glad I did.
    Present:
    IG: bknewtype
    May 20 2015
    PA
    Hope that helps!
    That does make sense. I never even considered Eibach until you guys mentioned it, just because with Audi H&R is just all over the place and what most use. I am not bias on brand though, so long as it does the job!
    Apr 29 2016
    Pennsylvania
    Thanks for the pics and insights into which springs to get. I think the Eibachs are best for my need since they do have cab specific springs. Part#155103.140 drop about 1" fronts and 0.6" rears. I do have 3years 3rd party warranty on the vehicle so if i paint them black they're will look like stock if my struts go im still covered.
    Established Member Two Rings CG3D's Avatar
    Feb 28 2011
    Kenosha, WI
    For what its worth to add this to the comparison pile - H&R Sports with 20" CH-R's
    2009 Audi S5 | Meteor Gray | Magma Red | H&R Sport | BBS CH-R 20x10.5 | AWE Track | Drive Select | Side Assist
    Past: E55 AMG, 1970 Nova
    IG: @CG_3D
    Feb 27 2014
    Dubai
    Quote Originally Posted by swag View Post
    They come in black and look 100% stock, only the small Eibach writing will give the game away but you could polish that off the springs if you wanted to be ultra thorough.
    Apr 29 2016
    Pennsylvania
    Perfect drop
    Feb 27 2014
    Dubai
    If you want that drop but keep the ride nice, go for the KW H.A.S.
    Apr 29 2016
    Pennsylvania
    Quote Originally Posted by CG3D View Post
    Perfect drop on your coupe but i have a cab
    Apr 29 2016
    Pennsylvania
    Yea but the KW H.A.S. costs 3X more than the Eibach. I can put that $ towards installation
    Feb 27 2014
    Dubai
    The KW H.A.S kit for the cabrio should be part number 25310078
    http://www.kwsuspensions.net/kw-hohe...html?typ=25647
    Same part number for S5 Cab
    http://www.kwsuspensions.net/kw-hohe...html?typ=20825
    May 20 2015
    PA
    The only reason to go with the KW's is to take full advantage of the drive select right? So if someone's S5/RS5/A5 didn't have drive select there would be not point to get the KW HAS right?
    Feb 27 2014
    Dubai
    Nope, the KW's give you the adjustment flexibility of a coilover but retaining your original dampers. Don't get wrapped around the axle on drive select and these springs, yes they work well with ADS because you get to keep the factory adjustable damper but that's not essential, they work just as well with normal dampers.
    I just posted it up because you liked the drop of the H&R Sport but I don't think you'd want the harsh ride that comes with the H&R's. Stick with the Eibachs, you'll love them.
    Apr 29 2016
    Pennsylvania
    Quote Originally Posted by Gonzoe11 View Post
    Got a question for u since u already own a B8 cab. Is there a drop difference in the rears when the top is up/down? "RubCity" only appears when ur riding with the top down right?
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Rubbed either way with the H&R coilovers. Top up/Down didn't matter. I suspect the coils were not designed for the extra weight of the cab.
    Senior Member Two Rings mufflerman's Avatar
    Jan 08 2009
    '01 S4 Avant 6 speed, '13 RS5, 993, '99 360 coupe 6 speed
    Sacramento
    We've installed all of the mentioned brands for customers, my opinion of the ride difference between them is nominal. I don't spend a huge amount of time out side of a short test drive in them however.
    IMO, if ride is paramount with a drop do a full coil over setup, it's a lot more money but you get infinite adjustability in height and an researched and developed spring/damper setup that works well together. If you don't want to spend the money on coil overs do the KW H.A.S., it's the best in quality and you get the adjustment factor as well.
    Apr 29 2016
    Pennsylvania
    Does it sit lower when the top is down? Reason i asked bc im going with the Eibachs cab springs. 1" drop fronts and only 0.6" rears. I figure the rears will drop a little more when the top is down?
    Apr 29 2016
    Pennsylvania
    Just ordered a set of Eibachs from Tire Rack for only $234. Will post pics of before and after installation.
    Feb 27 2014
    Dubai
    Give them a few weeks to settle in after install before you take those "after" pics, I know mine took a while to settle to their final height.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    I never noticed a change in ride height with top up or down. That drop seems reasonable for the cab. +1 on JamesRS5 comments. The H.A.S. kit settled 1/4" lower after a few weeks.
    Good luck. and don't throw away the OEM parts in case you're not happy with the result.
    Apr 29 2016
    Pennsylvania
    I alway kept my oem parts just in case if i want be stock to sell/trade a few years down the road. Well should i get the alignment done right away or wait a few weeks for the springs to fully settle?
