Results 1 to 20 of 20
    May 09 2010
    North jersey
    Reverse passenger rearview tilt stopped working
    Anyone have this same issue? It worked fine until yesterday..
    The same thing happened on my old b6 s4 and I think they changed a sensor or something to fix it.
    Thanks for any insight!
    Apr 19 2016
    PNW
    What year is this available on?
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by rulaxin12 View Post
    Make sure that you have the selector set on the passenger side mirror. Maybe set it to the middle position and then back to the passenger mirror.
    Oct 20 2008
    Denver
    Quote Originally Posted by eurotic View Post
    +1
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by AudiTFSI3o3 View Post
    +1
    +2
    I had the same issue and this was it.
    Aug 12 2013
    Lexington KY
    Yup, the adjustment switch must be on the passenger mirror for it to work. I think MMI has an option as well. Maybe just look through there.
    May 09 2010
    North jersey
    i had mine set to passenger side but still no tilt!
    Aug 06 2015
    MA
    Set the knob to passenger side. Put car in reverse. Tilt the knob down to set the mirror down position to where you want. Set knob to mid, should reset to level height.
    May 09 2010
    North jersey
    going to try that now! Thanks mungie!
    Oct 31 2013
    Morris County, NJ
    Is this on prestige models? I don't think my p+ has this feature.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    May 09 2010
    North jersey
    Quote Originally Posted by mungie View Post
    This worked!! thanks mungie.
    May 09 2010
    North jersey
    Quote Originally Posted by mmm def View Post
    pretty sure mine is a P+ not prestige. try what mungie said. I washed my car on Sunday and i want to think my seat memory was reset or something. When i got into my car, the seat was automatically readjusting to my memory 1 position. I wonder if there is a way to get the seat to move back while you get out and in, then go to your memory setting once you are seated.
    Apr 14 2016
    2014 Cayman S, 2004 A4, 2005 4Runner
    Eastern PA
    Every few months it seems I wind up having to reprogram mine using this process. At first cycling between right mirror and center would get it to work again, but once that stops working the reset process is necessary.
    Nice process description.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Your P+ will have this feature IF you have memory seats OR you changed the settings with a vag com. I had it vagged on both of my non memory seat Prem+. However, with the vagged cars, the mirror does not always return to the exact same position when you go forward. It really depends what position you set your mirror.
    Oct 31 2013
    Morris County, NJ
    I don't have memory seats. Could it be that?
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    That's exactly what I had to do when I was trying to figure out why mine was unresponsive. My MY16' has been intermittent with it. Scanned via VAGCOM and no codes. Seems to work best and repeatably if you keep the detent in the middle and only switch to passenger side when about to reverse.
    Hate how my old lady's 2013 C300 4matic does it automatically without toggling knobs ANDDD she has power folding mirrors and I don't
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Senior Member Three Rings sc117's Avatar
    May 11 2015
    2015 Audi SQ5
    NOVA
    I just tried this and It worked. I didn't know I had this haha
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    You'll more than likely have to go through the same process again down the road; the "memory" of the position likes to disappear at random times.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Thanks for posting this. Mine stopped working and I couldn't figure out why, totally forgot about having to turn the trim knob lol
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Aug 06 2015
    MA
    I've also read that if the knob is set to passenger side, defrost will not work on the mirrors.
