Results 1 to 24 of 24
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    Holy CEL Batman. You'll never guess what the mechanic did next..
    So had a few CEL's lately. Some MIL on, some MIL off.
    012555 - Low Pressure Fuel regulation
    P310B - 008 - Fuel Pressure Outside Specification - Intermittent
    008851 - Fuel Pressure Regulator Valve (N276)
    P2293 - 002 - Mechanical Malfunction - Intermittent
    001110 - EVAP System
    P0456 - 001 - Very Small Leak Detected
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit - Intermittent
    012425 - Signal Line for Fuel Pump Electronics
    P3089 - 002 - Electrical Malfunction – Intermittent
    001287 - Idle Control System RPM
    P0507 - 001 - Higher than Expected. - Intermittent
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - - MIL ON
    After a lot of research on wikivag, etc. I have replaced my fuel filter which at 127,000 miles is probably way overdue. That so far seems to have the fuel pressure issues dialed in. Before changing, the LPFP duty cycle was about 77% on average at idle and gradually it has come down to around 50% at idle. I have also ordered a new thrust sensor as I came across that, too. Then on the lean idle and EVAP leak, I replaced the PCV and breather hose and have a new N80 valve on the way.
    Not sure on the N276 code though as it refers to the HPFP. I just changed the cam follower like 2k miles ago. Checked it again the other day and when I pulled the HPFP off the valve cover it kept making this hissing noise like it was leaking pressure somewhere. This continued when cycling the piston. Anyone experience that?
    HPFP log for reference.
    https://onedrive.live.com/redir?resi...nt=file%2cxlsx
    Oct 24 2015
    Perth, WA
    What mechanic?
    My respray thread
    Apr 08 2005
    Portland, OR
    This mechanic!
    Sep 03 2009
    San Antonio, TX
    I'm thinking there's something going on with the fuel system...
    MY BUILD
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Quote Originally Posted by IKE20VA4 View Post
    This mechanic!
    Click bait.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by allstock View Post
    Click bait.
    EXACTLY what I was thinking.
    My respray thread
    Jan 05 2015
    London
    Are you mapped btw? Or what altitude are you at? Your MAF reading goes quite a bit higher than mine!
    Apr 08 2005
    Portland, OR
    Stage 1 Revo tune. That is all. Maybe 90ft above sea level...
    Feb 15 2016
    Cambridge,Ontario
    definite click bait approach..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 23 2011
    Is this gawker or buzzfeed now?
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    The internet is freaking out about these CEL's!!
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Good reason to
    /endthread
    /startpetphotos
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    Quote Originally Posted by Sanjman View Post
    Good reason to
    /endthread
    /startpetphotos
    Release the hounds!
    06 Dolphin Gray tip 2.0T
    GIAC Xplus | USP Testpipe | RevMotoring Springs | 19X8.5/9.5 Niche Targa | pioneer 80PRS | Taramp's HD1200, HD8000, HD10000 | 18-Sound 6's | B&C 8's | Audiocontrol Three.1, Audiocontrol Epicenter | Clarion EQS746, MCD360
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    Quote Originally Posted by miA4 View Post
    Is that a new Mercedes? the CEL?
    Mar 19 2014
    There's definitely something wrong with the n276 connection. It's not the pump, but a valve. Use the search you'll see what I mean.
    Apr 08 2005
    Portland, OR
    I've actually read a lot about the n276. It's attached to the pump though. Can't seem to be replaced apart from the pump though?
    Thanks for the serious response though..
    Dec 23 2011
    Buy a cheap used hpfp and swap them
    Apr 08 2005
    Portland, OR
    Good call...
    Feb 15 2016
    Cambridge,Ontario
    I just replaced my HPFP due to a failed follower .. is the part shown below the one you need ?
    https://www.youtube.com/watch?v=dQw4w9WgXcQ
    1976 Yamaha XS 360
    Nov 16 2006
    Skokie, IL
    Video doesn't work in Umerika
    But here's one:
    https://youtu.be/oHg5SJYRHA0
    Deactivated Three Rings
    Dec 30 2014
    86 Toyota Pick-up
    Birmingham, AL USA
    Veteran Member Three Rings idrinkv8's Avatar
    Nov 01 2008
    Quote Originally Posted by p0isin View Post
    Mechanics hate him! People are fixing CELs now with this one weird tip!
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by idrinkv8 View Post
    strangely enough if you eat this one weird food while working on your cell you can lose 10 lbs of belly fat.
    1976 Yamaha XS 360
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
