Results 1 to 10 of 10
Thread: Break wear
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    Brake wear
    So i have a 2014 rs7 and it currently has 41,000km on it. The brakes and rotors have been replaced before under warranty for the rotor having a very large lip. This was covered under warranty as 21k should not produce a lip of that magnitude under regular driving conditions with the brake pads having as much meat left on them as they did. Now here's the issue, my brake pads are at a healthy level while my rotors have developed a lip and Screech like a 1980's corolla. Has anyone else experienced this issue? My dealers fighting me on replacing them under warranty and would like to hear if anyone else is having this issue
    Jul 10 2014
    United States
    not uncommon, our sleeper cars like to eat brakes...I had mine replaced at 22k miles with disc-Italia ceramic pads, mine had the lip but i'm giving car back in December so I said screw it. Also didn't purchase the dampening kit. Right now the brakes do squeal a little but it's a much more high pitched squeal and not as annoying as OEM. I'm sure it's because of the lip that the rotor has but the trade off is no more dust. So to stop myself from babbling on further, I'm surprised they covered the 1st one under warranty at all, as brakes are wear and tear items and as such really shouldn't be warranted.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Do a search. Multiple posts regarding relatively short life or RS7 brake pads and rotors. First one has been covered in some instances, but that's usually been it. It is one of the main reasons I haven't even bothered researching used RS7's. Even if I could afford the car, I couldn't fathom replacing pads/rotors damn near annually.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Junior Member Two Rings mchltschr's Avatar
    Aug 28 2015
    Milwaukee, WI
    Copy and paste of my post on another forum:
    My last visit was a big disappointment so I hit up a local euro shop that came highly recommended. I've actually used them to mount/balance my winter wheels and tires. Anyhow, I told them the need (squeal + some chatter) and they cut all four rotors due to glazing/pad deposits then rebed the pads. Validated what Audi said that my pads were about 75-80% and the new rotors should be silent and hold me till my pads are done.
    About a week now and they have been perfect. No sound, no chatter in the pedal when braking. Very happy. Had them bleed and refresh the brake fluid while they were at it. Cost about $340 all in.
    2014 A6 Prestige with 25k miles.
    In short, turn your rotors for a temp fix, buy new rotors and pads for a longer term fix.
    Feb 08 2014
    Thanks for the posts! i figured this car would require lots of up keep and go through things quite quickly but didn't anticipate brakes at every 20k! i'll dig into the forums as i didn't know this section was so populated!
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    I'm having my 25k service done at 21,600 miles due to time, not milage.
    Have 5-6mms left on the front, 6-7mms left on the rear. However, the brakes are really starting to squeak, bad. Thankfully I got Audi Term Care Select so I get a free brake service anyway. What's weird is they are loud when they're warm and quiet when cold... not sure why.
    Now these are big, heavy cars and these brakes do an amazing job and bringing 4300 lbs to a stop. While the squeaking (really, howling) bugs me I'm okay with some level of it considering they are performance parts.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    My front brakes and rotors were replaced with OEM at 19K miles. Never a squeaking problem before or after. My rotors had some degree of a lip when I replaced them but I wasn't surprised and considered having to replace brakes and rotors at 19K miles as a cost of doing business. These cars are gonna eat brakes.
    Feb 08 2014
    hmmm glad to hear i'm not alone. Its quite odd as i'm coming from a s4 which is way lighter but still somewhat performance oriented i guess this brake wear is really just a cost of business with these evil monsters.
    Veteran Member Three Rings Demandred's Avatar
    Jul 25 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    My C6 RS6 sedan went through a set of Rotors and pads in 10,000 km (just over 6000 miles) and those bad boys hurt like a bastard in cost to replace :(
    I wasn't even driving it THAT hard
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Jul 27 2013
    Australia
    Some dealers are quick to advise you need new rotors. If they are not undersized (thickness of rotor less than the min) there is nothing wrong with machining the rotor and not replacing it.
