Results 1 to 9 of 9
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    Servotronic steering questions
    Just purchased an 06 2.0T that has steering issues. Im not too familiar with how the servotronic steering should feel.
    I pulled the relay and the steering at idle/low speed was heavier, but nothing crazy. With the relay in place steering at idle is noticeably lighter but at about 20 it starts to get heavier and around 40mph it feels the same as when the relay is removed.
    Also tried a different relay with the same results.
    There is also some creaking when turning the wheel sometimes.
    Time for a new rack?
    -06 A4 2.0T
    -97 A4 1.8T
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    You def seem familiar with Audis...so I suspect control arms / tie rods are relatively new? I'd start there as those are more "creaky" type items.
    Aug 09 2007
    Syracuse, NY
    Quote Originally Posted by IKE20VA4 View Post
    haha I've worked on a few of them. control arms all looked good, nothing felt loose, no clunks over bumps. The creaking isnt there all the time... or even in the same steering wheel position. It does sound like its coming from the rack area but its hard to pin point as I havent figured out how to continuously replicate it.
    -06 A4 2.0T
    -97 A4 1.8T
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Checked your power steering fluid? Any leaks?
    Check out rackdoctor for a new steering rack....OEM rebuilds
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Aug 09 2007
    Syracuse, NY
    Thanks, Ill check out their site.
    Fluid level looks good, no leaks.
    Only thing I seen was the passenger side boot was torn but the inner tie rod still looks good and doesn't feel like there's any play in it.
    -06 A4 2.0T
    -97 A4 1.8T
    Aug 09 2007
    Syracuse, NY
    Is it possible to swap in a non-servotronic rack?
    -06 A4 2.0T
    -97 A4 1.8T
    Mar 06 2012
    CA
    I changed my power steering fluid in the reservoir 4 times in order to flush it through the system, made a big difference for me. My creaking was worn out sway bar bushings, might want to give those a look.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Campy66 View Post
    DIY for that somewhere Campy?
    My respray thread
    Aug 09 2007
    Syracuse, NY
    Quote Originally Posted by Okedokey View Post
    http://www.audizine.com/forum/showth...luid-flush-DIY
    -06 A4 2.0T
    -97 A4 1.8T
