Originally Posted by
switchedstance
Good idea - but won't do here - they state they do not meet the requirement for "Chains" in CA
Basically the mountain passes in CA require all vehicles to be properly setup for winter driving = either dedicated snows or full fledged chains....
OP - I wouldn't run chains over summer tires on the peelers - as noted the tires are not well suited for the temps you'll see - and the chains do a number on the actual rims themselves..... You're better off with an alternate set of wheels for this purpose - although if it's only for 2-3x per year - a rental vehicle is probably an even better solution (assuming you can rent one with the required winter hardware (chains or dedicated snows).
EDIT: You don't want to run just summer tires in the snow (no chains) - even on car of this nature - TRUST ME - I had my summers on for the last minor snow fall (2 inch) earlier this year - nothing like only getting 1/2 way up my 30 deg driveway to put on the brakes - only to notice the car is sliding backwards downhill - you may be able to get the car moving but steering/braking control will still be NILL
