I recently have been trying to figure out why my fans wouldn't come on, and I checked relays in the ECU box (IDK if there is anything there related to fans, but I was checking anything and Everything) well I guess I didn't fasten the box down well and it rained and flooded it, car didn't start, so I replaced the relays, the car started, but It didn't last long, mind you, it ran fine before the rain incident, just the fans didn't work, but as long as the car was moving, it had no problem, well now there were a whole slew of issues and idek where to begin, I got it scanned and well.......here it is...lol.....
VIN: WAUAF78E47A128769 License Plate:
Mileage: Repair Order: home
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH14--- Serial number:
Coding: 0104010A02070120
Shop #: WSC 07318 444 82871
VCID: 2E53E83AB9B7486E36F-807B
7 Faults Found:
000280 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 217292 km
Time Indication: 0
Freeze Frame:
RPM: 150 /min
Load: 80.4 %
Speed: 0.0 km/h
Temperature: -40.0°C
Temperature: 39.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 0.000 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 217388 km
Time Indication: 0
Freeze Frame:
RPM: 1103 /min
Load: 23.1 %
Speed: 13.0 km/h
Temperature: 22.0°C
Voltage: 13.716 V
001669 - ECM Power Relay Control Circuit (J271)
P0685 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 217388 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 38.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
008854 - Fuel Pressure Regulator Valve (N276)
P2296 - 001 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 217396 km
Time Indication: 0
Freeze Frame:
RPM: 3927 /min
Load: 10.2 %
Speed: 0.0 km/h
Temperature: 21.0°C
Voltage: 13.462 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
049409 - No Communication with Transmission Control Module
U0101 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 217396 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 37.0°C
Voltage: 0.000 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 217396 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 39.0°C
Voltage: 0.000 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 M HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0020
Revision: 00000009 Serial number: 00000001036860
Coding: 0000001
Shop #: WSC 06325 000 00000
VCID: 326BFC4AAD8F6C8E527-8067
6 Faults Found:
005956 - Tiptronic Recognition Switch (F189)
P1744 - 000 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 896 /min
RPM: 0 /min
(no units): 13.0
Torque: 14.0 Nm
Temperature: 82.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 1
005924 - Starter Interlock Signal
P1724 - 000 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 43
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 1184 /min
RPM: 70 /min
(no units): 3.0
Torque: 84.0 Nm
Temperature: 20.0°C
T.B. Angle: 14.4°
Bin. Bits: 1010 0 0
005939 - Tiptronic Down Switch (F189)
P1733 - 000 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 576 /min
RPM: 0 /min
(no units): 13.0
Torque: 90.0 Nm
Temperature: 31.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 1
005985 - Shift Lock Solenoid (N110)
P1761 - 000 - Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 96 /min
RPM: 0 /min
(no units): 1.0
Torque: 0.0 Nm
Temperature: 19.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
005975 - Supply Voltage
P1757 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 864 /min
RPM: 0 /min
(no units): 13.0
Torque: 108.0 Nm
Temperature: 19.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
006231 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 96 /min
RPM: 0 /min
(no units): 1.0
Torque: -32.0 Nm
Temperature: 43.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004525
VCID: 2C57E2328FAB3A7E18B-8079
4 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0202
Hex Value: 0x0024
Hex Value: 0x0186
Hex Value: 0x0000
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x0013
Hex Value: 0x85A0
Hex Value: 0x0000
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x0028
Hex Value: 0x018D
Hex Value: 0x0000
01315 - Transmission Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x1202
Hex Value: 0x0013
Hex Value: 0x44AA
Hex Value: 0x0000
Any help into getting it started and running good, would be much appreciated, some of the stuff I know I can fix, but I would just like to narrow down the issues so im not just buying my way throught POSSIBLE issues.
-Many thanks
Anthony
