Results 1 to 7 of 7
    Jan 10 2011
    nyc
    passat b5 s4 2.7t swap stage 3
    the car runs very well starts right up and idles smooth boost comes on strong!!!
    ENGINE:
    2.7t engine from a 01 b5s4 100k miles
    Gates racing timing belt & waterpump tensioners and rollers replaced
    new thermostat housing
    new valve cover gaskets
    new timing chain tensioners passenger side
    new cam sensors both sides
    new crank sensor
    new oil pressure sensor
    new oil pan
    new oem Spider pcv Hose
    new upper and lower radiator hoses
    new heater core hoses
    new Coolant Bottle
    new radiator
    new oxygen sensors both upstream and downstream
    034 motorsports egr delete block offs
    034 motorsports silicone throttle body hose
    034 motorsports silicone lobster hoses
    034 intake manifold spacers
    k04 turbos
    034 motorsports stainless turbo bi pipes(tapped for meth)
    3 inch dual downpipes to a custom hardlines by swoops built stainless side exit exhaust
    power steering line off pump converted to AN fitting with stainless line by swoops
    034 motorsports Engine Mounts
    BFI Front poly Snub Mount
    Autospeed stage 3 tune
    dual splitter valves
    630cc injectors
    Walbro High flow fuel pump (E85 Ready)
    ngk plugs
    034 motorsports 85mm maf housing and rs4 silicone inlet house
    new BOSCh gel battery most expensive you can get
    godspeed FMIC
    TRANSMISSION:
    factory 5speed transmission
    new trans mounts
    new axles and bolts both sides
    short shift kit
    fidanza lightweight flywheel
    6 puck stage 3 unsprung clutch
    BRAKES
    b5 s4 aluminum uprights and full s4 brake conversion with stainless lines
    front akebono pads and cross drilled rotors
    NEW rear calipers
    New rear hub bearing assembly
    rear mintex pads and brembo slotted rotors cadium plated
    SUSPENTION
    fk coilovers few yours old pretty soft in my opinion for the power
    lltek rare strut bar
    new control arms
    new tie rods
    all new bolts and a alignment
    started collecting some air ride parts that I may throw in for the right price
    INTERIOR
    b6 s4 steering wheel (no airbag lights)
    beetle headrest front/rear
    aem digital boost gauge and colum pod
    euroimpulse weighted shift knob
    Exterior
    new euro ecode headlights
    yes I have the factory bumper it will require trimming to fit or you can swap to smic
    new orange corner
    Euro trunk from Germany
    19x10 carlsson wheels tires 225/35/19 stretched
    needs:
    needs the ABS module rebiuilt (electrical side)
    power steering bottle slow leak
    paint job
    interior work
    I spent a lot of money buying all new electrical and hoses so I wouldn't have any trouble taking trips
    looking for 5k or best offer no trades please as I have to many cars now 917-200-7537 I have more build pics I can text or email to you
    - - - Updated - - -
    May 05 2016
    alaska
    Where are you located?
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jan 10 2011
    nyc
    Queens NYC 11412
    Nov 03 2011
    All Over!
    Sweet looking Passat.
    FWD or Syncro / 4Motion?
    1986 Type 85 Audi 90 quattro
    Senior Member Three Rings 155VERT83's Avatar
    Jun 30 2009
    ‘05 Porsche 997 Carrera, '15 MBZ C300 4Matic
    Alexandria, VA
    Concur. GLWS.
    2021 Tiguan R Line (replaced 2012 A4 S Line)
    Mar 08 2017
    Jersey
    How much for strut bar
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    Quote Originally Posted by hose View Post
    About tree fiddy
