Results 1 to 11 of 11
    Jan 25 2016
    Need help identifying bolt
    The 4 bolts you need to remove near the headlights to put it in service position
    The two on the left side of the picture
    I searched some parts sites and even asked the ECS people via chat but they couldn't figure it out either.
    I know they're torx but head doesn't matter as long as they fit, I can just buy 4 new ones.
    Sorry for the stupid question!
    Thanks
    Nov 03 2011
    All Over!
    I bought a stainless set of those torx-head bolts, with matching washers. Got mine off eBay, same dimensions as the originals. I did the same with the headlamp retaining bolts too.
    My engine set-up doesn't require the cold air intake to be used, so I didn't replace the screws. Though any black Philip-head screws would do.
    1986 Type 85 Audi 90 quattro
    Jan 25 2016
    What were the dimensions of the ones you got off ebay?
    Nov 03 2011
    All Over!
    Quote Originally Posted by elduderino200 View Post
    For the Torx-head bolts: M6x20mm.
    For the washers: 6.4x22x2.75.
    The Torx-head bolts for the lock carrier and the headlamps are the same, I checked with Audi's OEM versions.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Side bolt is PN N01021710, M6x20mm. New part number is N01021723
    Washer for bolt is PN N90066201, 6.4x22x2.75mm, New part number is N90066203
    Air intake screw is PN N0139649
    Edit- Nollywood slides in to take the glory before me! At least I got PN's
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Nov 03 2011
    All Over!
    Haha, Redline. I didn't think to check the part numbers.
    Jan 25 2016
    Awesome thanks to you both
    Oct 02 2006
    Wadsworth,OH
    FYI we were able to pull up the hex head bolts which are the same part number redline gave but that doesn't seem to match the bolt in the pic. Unless the hex bolt is what is supposed to replace the torx for the supersession.
    Below is a 6X20mm torx. This is from the B6 though, but should work as its the same size and style.
    Jason
    Jan 25 2016
    Thanks Jason, I figured it would probably be a fairly common bolt used in a few places. The fact that it's on the b6 is hardly surprising.
    In any event I already ordered 4 new hex bolts with 4 new washers. I really only needed 1 but having the whole situation homogeneous would probably be better.
    Dec 05 2007
    They are incorrect in the etka. That is why many have issues sourcing those bolts.
    Nov 03 2011
    All Over!
    My dealership was able to identify them from my description, and where they are used.
    I only decided to go with stainless steel hardware due to the originals being quite prone to corrosion.
