    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    Question for those with after market sway bar
    Will the sway bar alone be sufficient for better hamdling or adding Alukreuz makes the addition even better? I currently lowered on Bilstein B12 if that makes any different.
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I've asked a similar question moving from stocks to larger aftermarket SBs. The consensus is yes, upgrading SBs on top of your lowered stance, will make a significant difference in handling. Adding an AK will further enhance the stability.
    Feb 21 2007
    Houston, TX, USA
    Thanks for the info!
    - iKe -
    2011 S5
    2011 A4 Avant
    Oct 12 2015
    northeast
    Today I had the 034 rear sway bay, with the 034 SB links, installed, and the answer to your question is a BIG YES. Tightens up the car big time.
    ***Just realized I have a B7 and you are talking about a B8.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    ^^^ The gains are huge no matter what platform. Loving my Hotchkis!
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
