Quote Originally Posted by hckymstr19 View Post
I don't think spider senses are required, I'm using the track as a perfect example, when using launch control I need to let the brake off right as the second yellow tree light is about to transition to the third and if the delay was unnoticeable or required "spider senses" then I should be able to release the brake at the third tree light and get good consistent reaction times. All I can tell you is the delay is by no means unnoticeable. I wish others would chime in that have a TCU tune.
Care to share a time slip or two?
