Results 1 to 16 of 16
    May 11 2014
    United States
    Apr TCU tune launch control question
    I'm sure everyone is aware of the delay between the time you let off the brake and the time the clutch engages and you take off. I was wondering if anyone knows if aprs TCU tune eliminate this or makes it any better or if anyone knows of any TCU tune that eliminates it or makes the delay much less noticeable. Let me know guys.
    Deactivated Four Rings
    Jun 23 2011
    Our EPL TCU tune shortens this delay and many other things that are shortened with the TCU tune.
    May 11 2014
    United States
    Well actually I currently have the Epl stage 1 and epl TCU tune and the delay is the same as stock.
    Jun 23 2011
    Our TCU tune does decrease this delay. How are you measuring it and are you sure you have the TCU flash installed?
    Aug 21 2014
    Boston
    Quote Originally Posted by hckymstr19 View Post
    Not sure, but there was an updated EPL TCU file posted the last week of April, maybe this is the ticket?
    I have EPL as well, honestly havent tried the LC yet..
    2015 Ibis White S4 DSG
    May 11 2014
    United States
    I am 100% sure I have a TCU flash, actually Tony is trying to work on a launch control issue I am having with shifting early. And I am measuring it by my senses. If it is decreased it is not perceiveable.
    Aug 21 2014
    Boston
    Im almost positive the 04/28/16 revision of the TCU file was specifically to address this., not sure about the lag though
    Registered User Four Rings
    Sep 06 2007
    Its 37% quicker in the epl file.
    The whole lock up process stock takes roughly .55 seconds, so thats roughly .365 seconds "tuned". Unless you have spider senses, Im not sure anyone could measure that difference seat of the pants. That said, it will be noticeable 0-60 or on a 60 foot because the car does leave a stop harder.
    Ive asked my staff to stop posting in this thread and this will be the last/only time I post.
    I apologies the original question was derailed.
    Mar 20 2015
    McKinney,TX
    I have APR tune, the delay is greatly reduced not totally absent
    May 11 2014
    United States
    Quote Originally Posted by Tony@EPL View Post
    I don't think spider senses are required, I'm using the track as a perfect example, when using launch control I need to let the brake off right as the second yellow tree light is about to transition to the third and if the delay was unnoticeable or required "spider senses" then I should be able to release the brake at the third tree light and get good consistent reaction times. All I can tell you is the delay is by no means unnoticeable. I wish others would chime in that have a TCU tune.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    I have the apr tcu and the delay is terrible! I have emailed apr 3 times for a file without launch.Still no reply! I will give it another few weeks and if still no reply I will get a hold of Tony.Just hate to spend the $ 2x
    Sent from my SM-G900W8 using Tapatalk
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    Care to share a time slip or two?
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by s4matty View Post
    have you cut any 1.5x 60's yet with their tcu?
    Aug 15 2015
    2 feet
    Niagara canada
    I hit 1.63 with the mash technique and 1.75 is best with the launch
    Jun 04 2018
    Orange County, California
    Tried to launch for the first time with APR TCU tune. The tech that installed set the RPM @ 4000 but it doesn’t seem to actually engage.
    I turn off ECS, mash the brake then start to mash the throttle but the car lurches a little and the RPM never goes beyond 2,000 RPM.
    Not sure what’s wrong
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by Jamen View Post
    Make sure you hold down the ECS button til you get a message on the screen behind the steering wheel that says ECS OFF. also make sure you’re in dynamic mode and the gearing is set to S1. Sometimes mine likes to be in D1 and I have to go back and forth with the lever. However, I made the ‘click the ECS off button rather than hold it down’ mistake for about the first month of having the tcu tune
